Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
giantkiller
Based upon Fatbird's post about clock synchronization, I will not undo Otto's jumpers on  GK4 but will jumper GK3(fatter gauge though) to put the 3 layers in parallel, modify the quadrature control down to 1 block of 4 channels instead of 2 blocks of 8 channels. Right now both 74ls193 are count up linked so I have 8 channels running. I will run off of one 74ls193. That will give control to 4 sets. The key was 3 frequencies. Vague talk again for 3 input signals. That frequency is to be tuned to the coils diameter or circumference. ;) This will let me get the compass spinning.
Then I connect my GK4! And the monster should breathe fire, eh?
When I reported my results on the heat & energy waves. They didn't last long because of the constant out of phasing condition only working with harmonics. The off harmonic is the confusion. I saw that many times changing freqs.
Hmmmm. I am all over this.
--giantkilller. 8)
Yamanashi Jr
Hi giantkiller, FatBird, all,
Mannix just posted about the CMOSmax308
http://www.rtcs.ru/pdf/Maxim/switch/MAX308-MAX309.pdf
Quote from: Mannix on January 16, 2007, 06:32:18 PM
Im using ss max308 sources.
I connected the output of the tongtail phase splitter...very low level. Then observed the wave form on the collector. I freq only. the other amps are still not quite complete.
what I saw at 30 khz was a little waver....just a tiny waver.
When the party is over
... I just keep dancing to the rhythm
giantkiller
I have used these in the past. They are excellant products. Maxim as a whole produces a wide array of conversion products. Their RS-232 single chip TX/RC are great!
--giantkiller.
mrl
One way you can limit the heating effect of the collector coils is my making them out of 1/4 or 1/8 inch diameter copper tubing.  Then you run water through them.  You now have water heater and an energy system for your home.
Loki67671
All,
I figured I would post a photo of my progress. TPU_004 under construction. That is 15 turns of 10ga solid copper in the core and 20ga magnet wire for the control winding.
TPU_003 is also in the picture. All three control windings are wound on a solid copper core of single turns I wire in parallel.
I haven't seen anything I would consider unusual to date. But I'm not doing my tests exactly as GK or Otto. I figure we already have testers/investigators moving that direction and posting their findings. I still have to figure out how I'm going to move a geomagnetic line of force and then let it recoil in a controlled fashion. Consider this, when a solar flare disturbs the geomagnetic fields, in some cases FREAKING HUGE quantities of energy are coupled. We are apparently seeking to perform a similar task except we are right in the middle of the field. Movin forward.
Regards,
JT
"When the water stinks, I break the dam, with Love I break it" .............Loki
"One must be completely immersed in the cold darkness to truly adore or loathe the light" .............Loki
Science, my lad, is made up of mistakes, but they are mistakes which it is useful to make, because they lead little by little to the truth." - Jules Verne
