Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
0 Members and 27 Guests are viewing this topic.
Sataur
@Turbo:
I think I understand your theory, but I am unsure how one would 'disable' the flux. I was under the impression that whenever there is a flow of electrons in a medium (a wire in this case) there will be a flux generated to some degree.
I thought the only way to have no flux would be to use a perfect conductor (frictionless generator in your model), which is far more conductive than even a super-conductor, and thus only possible in theory, not in the real world.
Am I correct in these assumptions? I may be off on the perfect conductor portion, but I imagine that it is the conductive 'friction' that creates the flux (or is it change in the momentum [acceleration] of the election that causes the generation of flux?)
giantkiller
In the GK4 initial test I hade 3 freqs into 3 lines all meeting up after the coil jumpering. The freqs were so fast due to competing on and off times that parts of my scope screen were just mere green swatches. Too fast for the time/cm display settings. And they were random.
--giantkiller. That is one to get the high frequency.
Bruce_TPU
@newbies
Why is it so difficult to understand that the collectors are a type of "transonic pressure tunnel"?  This is the entire basis of how the collectors work.  Without this understanding, you can pulse until you are blue in the face and get nothing.
Something incredible happens with the combination of resonant, harmonic and intermodulation AMPLIFIED, PHASE INVERTED signals shooting down the line, causing electrons to be pulled off of the wire by the OVERPRESSURE created by the Frequency.  Remember, Amplification=VELOCITY AND PRESSURE.
SM said EVEN if you don't quit hit the "right" chord (of three frequencies) you will still see some output.  If you do a word search of the new PDF, you will understand what Turbo is saying.  There is Mention after mention of the earths magnetic field.  This field is at 7.83 Hz frequency.  SM was inputing AC 7.23 (in the letter I posted on my thread) or 7.3 as SM says himself on one of the video.  Without tuning into the electromagnetic field of the earth, there would be no power, and a Vacuum would be needed to see the "impossible" results that SM stated.  All of his points were about a weak magnetic force being able to create as much useable power as the world has need of.  And he proved it.
Also if you read the PDF where he states that for some of the demonstrations they did not use a battery AT ALL in the collectors.  The Inertia (free electrons above the wire, particle accelerator) have the "cascade effect" / Avalanche effect / Turbine effect / what every you wish to call it, when SM uses the small magnet to provide a milivolt of electron movement in the wire, and then all heck breaks loose and you have high voltage.  This is from what is happening in the Wind tunnel and the avalanche of electrons knocking each other off of the wire, negating the flux is like a tree that is rooted in the ground (flux holding force)  Send a strong enough wind and up comes the tree roots and all, negating the "holding force".  But with these tunnels, we are talking about SPEED through amplification and PRESSURE through amplification and the natural tuning effect of the oscillations in resonance with the wire and in Harmonic.  The Harmonic is the real powerhouse.
Now, since we do not have investors to impress, we can pulse to our hearts content, but to do so without ALL the other pieces will not yield a working TPU.  We need to pulse low voltage and high voltage in PROPERLY constructed Collector wind tunnel, that are AMPLIFIED correctly according to SM's instructions.
Thank you for your time,
Bruce
Grumpy
SM used tubes to determine the frequencies necessary.  (I forget which ones.  I think one was a dual triode)
How do you determine them?  Can you tune your circuits to the your ring, or do you pull a frequency out of an orifice and wonder why it does not work?
Has anyone attempted to sweep their ring for a better frequency?
How else will you find it?
        -Frank Edwards
giantkiller
On the gk4 30awg 200 turns the resonant frequency was +-43k. But I applied 3 frequencies and all happy broke loose. I noticed the real effects happened in bands up 460khz. In those bands the current, heat, squealing, the voltage or the kicks appeared. But it didn't seem that all 5 were attached to any other. I would get kicks in operating bands of frequencies regardless of any quantifiable measurement except the frequencies. And then the pain occured.
I plan on letting the beast coil loose from its confines and feeding it. And like my last test on GKMTC1, if I notice any bodily anomilies the gk4 will go back in its box. Somebody else can be the expenditure for the week.
I also realized something else about the gk4 operation. And that is the pandemonious output based on the random mix of frequencies, the radically gyrating magnetic fields(tested with a neo), the dynamic impedances, and the coil flipping in and out of Q. As far as the quality goes maybe that was the inability of the coil to runaway. And what I experienced was the low end of operation to what I thought was a high end output. Runaway would signal done, no?
The iron wire was a configurable iron core wrapped in 200 turn 30awg. Just like mentioned in Celeste Energia patent. So I have 12 of these coils monofilar configured into 12 opposing Tesla coils at any given time. I think Niky would like that.
So I could safely put dc on the collectors to magnetize them then pulse the controls and the feedback segments. That would give a bifilar config. Does that make sense to everybody?
And not just the static items mentioned here but also the phase cancellation, momentary in phase, the mag field in the collectors jostelling about, the controller fields appearing and all the fields of all the coils snapping off at very high speeds. This thing looks like an aggravated hornet's nest. And to think I stuck my hand in it.
--giantkiller. The beast sleeps till the next pillage.
