Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
0 Members and 31 Guests are viewing this topic.
Rosphere
Quote from: Cavetronics Labs on May 30, 2007, 06:42:18 PM
Cap discharge "timming" works better then "chips" , because of the cap discharge(the cap moves its "stored energy)  in the system , the cap can store and move the store about , where as the chips can just act as switchs... unless the chip acts as a cap then its not so "waste-full" ....
The same thing applys to coils ,, as coils act like caps to... so what part is going to blow 1st ? the "chips" most likly..
Cavetronics,
Please post a circuit that will do this.
Thank you,
Rosphere
Rosphere
Quote from: bob.rennips on May 30, 2007, 06:48:12 PM
Quote from: Rosphere on May 30, 2007, 06:29:17 PM
Like so?
what software package are you using for modelling the electronics ? (The waveforms look like somethings from a electronics modelling package ?) Thanks. bob
Click here.
Cavetronics Labs
SCRs , S.S. Relays (reed-switchs) or combined NPN PNP
The Tesla coils uses spark-gaps to dump a cap in to the coil to rise the frec of the over all unit.... the cap will be the mixer and osc and part of the whole system...
or in case of the mower ,, use neon fireing a scr in to and outof a cap , or spark gap (using small high volts) to make gap
gn0stik
Quote from: Sauron on May 29, 2007, 04:07:43 PM
What if you disable the effects of the flux?
My unit operates on these principles.
Now the electrons float freely without anything holding them back.
Electrons at the sped of light are now a possibility!
How much energy can be converted from a stream of electrons traveling
close to the speed of light?
Let us ponder where the huge magnetic field comes from when you
explode an atomic bomb.
It is just created?
Is it converted?
Is it part of the earth somehow?
Is it just a by product of the fabric of time and space being ripped into
pieces in a fragment of a second?
I am curious as to where this unbelievably huge magnetic force comes
from during an atomic explosion...
It is something else to think about.
perhaps in connection with my power technology.
This discharge of magnetic energy is vary similar to the discharge
of magnetic energy during an atomic explosion. . .
http://en.wikipedia.org/wiki/Cherenkov_radiation
I want you to start and think of the generator principles the exact
same way that passing the sound barrier was accomplished.
So, There are three types of EMPs, one specifically from High altitude bursts. HEMP, which last about a microsecond and are a result of free electrons released by high speed photons from the blast, sent into the atmosphere by compton scattering, and getting trapped in the earth's magnetosphere. Which in turn generates an electrical oscillation, this in turn creates a fast spreading em field.
Secondary to this, is the MHD-EMP pulse which is created from the reaction of the earth's magnetic field to the one created by the burst. More specifically neutrons created by the blast interact and heat the ionosphere, and cause the earth's magnetic field to HEAVE. Supposedly this is a late time reaction, and actually occurs simultaneously with the first one, but the gamma emissions create an intermediate time signal.
The third type is called an SREMP or Source Region Electro Magnetic Pulse. This occurs with low altitude and ground based bursts. SREMPs create a huge magnetic pulse in the local area due to ground conductivity.
So, having said this, and it may not be 100% correct, but it's close, I haven't read up on it in a while. I do have a hard time tying it to the TPU however.
Especially since all three are caused by different aspects of a nuclear blast.
One is from ionization of the upper atmosphere, one from photonic discharges freeing electrons, and another from ground conductivity.
The only similarity that all three posess is the fact that they are all assymetrical magnetic fields in nature. And all three cause a displacement of the earth's magnetic field. I have to think about it some more.
bob.rennips
Quote from: Rosphere on May 30, 2007, 06:51:28 PM
Like so?
Click here.
Many thanks. That's a great resource.
