Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
devilzangel
Quote from: giantkiller on June 07, 2007, 12:24:50 PM
I am talking about wings and sonic booms here.
All of the tpus have no lumps on the outside only machinations on the inside and nothing located in dead center!
The wing is the rotating magnetic field. How do we create a sonic or magnetic boom? Just stick some aluminium in the way. This causes deflection and compression of the wave as it tries to swing past the ALuminium. The compression is the high speed flux and the vaccum at the non-turbulant side is the slow side. This causes dissymmetry in the normally radially equal field, hence the high interaction that equals the high flux interference, no? You speed that rotation up and flux compression is huge. The aluminium in the way can also cause the flux to break away from the ring itself, yes? The Helmholtz simulator showed the virtual toriod field created in space. The aluminium in the way actually enables the sonic boom as an interference in the traveling field path. See? Now what if we had many of these per second? Boom, Boom, Boom, Boom. Kinda looks like cannon balls, eh?
thats what i think also. it reshapes the mag field like they do on the sun .. it creates a drag on the field in the path of the block.
@all .. dont know if that gravity wave vid summary is a good explanation .. what the site uses for explanation sounds very much like weather cold draft .. the vid looks nice though.
devilzangel
devilzangel
Earl
Quote from: Motorcoach1 on June 07, 2007, 07:38:29 PM
@ Eral most of us don't have EXL would it be hard to post in PDF format ,,,mmmmm ? thanks
Hi MC,
I think what you meant to type is:
Earl most of us don't have XLS would it be hard to post in PDF format ,,,mmmmm ? thanks.
I attach a screen shot of the spreadsheet calculator showing what it does.
The office suite OPEN OFFICE is free of charge and will accept XLS files.
- If you only have a modem connection, then ask someone on this forum in your country to burn you a CD with OpenOffice on it and mail it to you.
- If someone wants a version saved in OpenOffice format, I can upload a spreadsheet saved in OpenOffice format. Just ask.
IMPORTANT
The previous version was locked and could not be used, so please delete this older version and then download this corrected version.
Regards, Earl
"It is through science that we prove, but through intuition that we discover." - H. Poincare
"Most of all, start every day asking yourself what you will do today to make the world a better place to live in."  Mark Snoswell
"As we look ahead, we have an expression in Shell, which we like to use, and that is just as the Stone Age did not end for the lack of rocks, the oil and gas age will not end for the lack oil and gas, but rather technology will move us forward." John Hofmeister, president Shell Oil Company
Earl
Hi All,
here is a screen shot of my spreadsheet calculator.
Regards, Earl
giantkiller
I will post about Ronnotes & Otto's latest coil here in case this post turns out to be wrong and the new coil is correct. I would not want to dirty the parade.
The input specs compared to the GK4 test on Jan 03- 07 are the same.
If you remove everything except the power supply and the bulb you get a closed circuit. I tried that with a 100w bulb against my truck battery. You get a red filament.
I am sure that when all the 3 frequencies are in phase there will be more power. They connect at the power supply. Would stand to reason when the frequencies are just right the amperage goes up. Also out of control coil resonance there would be more amperage. The coils look like dead shorts to ground.
As far as the mobius hookup goes the GK4 was 3 layers. This new coil is one. That does produce anomolies.
Both coils exhibit 90 coupling. By now we all know that works. One frequency works. I went over board with a stun gun to prove that.
The new coil secondary, using 30awg, turns length per segment is about 5" of 471 turns. 3 of these will fit on the 6" coil length of 18.84 inches with a gap of 1.2 inches in between. Without measuring, the primary of 26awg will fit also.
But wait! the spec mentions 24 - 18 awg. That constitues a change in mass.
(same weight of primary and secondary coils) How could this be possible then?
One would have to change the specs of the primary.
Now here is an interesting note:
The 6 and 4 are at a verticle angled height. Which ironically is the cone shape coil. This is Telsa's favorite and also produces the heighest COP. But with 12v driver this new coil arrangement needs to get more power from somewhere for the distance. In the GK4, every coil was butted up against everyone else. I had major coupling no matter how I looked at it or for that matter how it was hooked up.
But the most redeeming factor is the collectors of 1 turn. That equates to an incrediblely fast winding job. Rosphere has us beat with his motorize window shade coil winder of science. :D What is funny is that before everybody would grab huge spools and make huge coils in an instant. This new coil is incredibly simple and fast to make, yet we wait. :D
Looks like the horseshoe shaped one does exist. For the life of me I can't find that pic. It is a 15" and black with the control box in the center.
In looking at alot the posts I saw the you can drive this with almost anything. I have BJTs set up instead of FETs so I will try those.
I ,for one, see the need for an anomolous action here. I am not a doubting Thomas but am very curious as to what we are to see from out of the box here.
I hope we learn a great deal from the next new coil presentation.
--giantkiller.
