Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
0 Members and 36 Guests are viewing this topic.
Grumpy
Once you understand the mechanism - it will all be simple and make sense.
So, GK, step out of the box for a minute and ask yourself - what would be the simplest explanation - that instanious thought - what is it?
        -Frank Edwards
Motorcoach1
ok then we get back to primaries  and secodaries  2 windings = amplfiers or transformers simplfly -  Ottos ring is unique in it's form . this is uncommon in the electric feild  other than the gap. i can see the smaller ring as the antenna and reciver  in RF the outer feild being the amplifer. in acustics this might be true i this applacation i'm sure that Esa may look at this but may not comuicate about this fact. but it is a fact i the square furmula. I see it very interesting that the ring is in the center , I would have thought that it would be on the out side and be collective. vraitable. I saw this ring configuratio in a situation that needed so help so as the wire was exactly on top of each other , but in flat wind as Tesla did it it was beside each other flat to flat , i belive the 90 degree effet was to off set the 108 D effect to get the 45 d in the 3 factor occilation.  the calibration of AG unit to the 1 to 2 windings is stright as in Teslas fourumla . @ GK yes the copper tube has a great findi this senareo how observent or just good wardering in RF ......lighting mmmmm    ..trode tube ...dipole .... I thik the hot dog is do i the microwave 22 sec plus i pespi can empty
Motorcoach1
OK ...I have observed SM"s videos for a long time some things are good but the mechanics of the build are important in Ottos replication ,, the wire in SM's coils are on top and not on the bottom , i saw this straight off - interpolation of wiring was parallel no crossed wires as i could see - the AC in the RF Field will happen do the the back flow in the C steel ring ( or copper this is a fact no matter what u uses ) 180 freq in a wire to 180 gives ac current ask the guys at Bell telephone it happens. in the core section is hollow as per Otto. now doing the LMD test their's caps involved GK has done these test i believe. Border land proved this and JNL jabs set the preference on the fact and i did to.   Eistine said just a few thing make things happen  compressing for time and expand. Rosstine 10 nu sec rise well ok just a thought .
giantkiller
@Grumpy!, MC!,
Thanks for feeding the beast!
I made a wire model of the base of the new coil just to visualize a few things.
I will state a few starting facts.
Overunity can be gotten when we try to move the copper faster than it
is capable of moving. Anomolous functions occur.
http://magnetism.fateback.com/Overunity.htm
The speed can be induced by phase cancellation or conjunction of 2 or more frequencies.
Nailed it here: http://www.overunity.com/index.php/topic,1872.msg24372.html#msg24372
In case anybody wants to question why I mention the GK4 and the new coil in the same vein? Here is the model: Otto posted the block diagram and the next person winds it. Ronnote and I coming up with the actual physical attributes and being the winders. The basic points are the starting facts here.
On the new coil the pulse on the 4" ring has a tighter diameter and an opposite direction than the 6" ring. Damn! Can you see all the clamoring of Poynting vectors? This has very strong similarities to Hutchison's experiments. Field within field.
And the control coils are the transducer.
I can see the field dynamics. This one is just as busy as Otto's first mobius jumpering on the GK4.
The distance of the 4 & 6 inch rings in the new coil is greater than just placing the 4 inside the 6. Something to do with with specs of the lamp wire at +12v. That would equate to the B field running in 2 different directions not only through the ring but also the Flux lines in opposite directions. Which would build interaction in a tremedous amount.
The 4" placed in it's position can also produce a very small phase shift in conjunction with the 6". But that small size is most importante. The exact centers of both toroidal field are sitting on 2 different horizontal planes so the fields cross each at a declination of 45 degress of 4" externally and a inclination of 45 degrees of the 6" internally.
So a small offset can be achieved with mechanics greater than by any electrical means.  'No mass circuitry involved here'. The ratio of the 4" to the 6" will give the operation the rotational shift due to the different path lengths and pulse directions in opposition.
Where's the collection? The higher level of magnetic interaction naturally feeds back onto the copper from the surounding field interactions.
In looking at Hutchison's demos, this time the target is the copper in the circuit instead an external material. We are kickin' our own arses!
--giantkiller. Johnny! Put that coil down before you go and hurt yourself!
