Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
giantkiller
I am going to hold off on any new testing of coils during space shuttle re-entry and landing.
--giantkiller. :D
giantkiller
Here is the inital result from the spreadsheet i posted. http://www.overunity.com/index.php/topic,2535.msg36495.html#msg36495
200 turns from mid point in both directions to the marks on the visio printout for angular distances.
I wanted 600 turns but the i could only fit 400 per segment. That is where the sheet is wrong. but the wire length is right on.
I drove 2 nails in my yard fence @ 30 feet apart for 60 feet folded in half. wound both halves onto spools. Wound each spool for 200 turns from mid point onto 6" ring.
Take special note of the smooth 30awg reflection.
--giantkiller. Cruisin'
giantkiller
I hate posting all over the place, but oh well.
There are alot of ways.
I will dissertate again. The open tpu has 4 on a horizontal plane. Somewhere on the guy there is a receiver to pick up the clashing fields. Like Roberto posted about the sharp edge being very high speed. I didn't see that before but now I see it.  The other tpus have that wing running along the vertical plane. The open tpu is multifilar with co-mingled fields. The other tpus (SM4 & SM6) could be that also. The SM17 uses 2 frequencies. That looks like the vertical wing with top and bottom facing edges also. I posted about the wing edges on the GK4. I have tons of them and they don't line up 100%. 3 layers worth. Wavewatcher posted about opposing frequencies and the clashing fields. I used 3 frequencies to achieve this. Sloppy though. That is why I am  winding the Otto/Roberto single wing tpu. It has the mobuis technique that Otto posted for us to do back in December 2006. I also ran a stun gun through GK4. Wow! Vertical RE dartlets all around the ring where ever I ran my finger close by. Freaky.
It doesn't bother me if this next step isn't the finish line. Every test I ran blows my tie back. And I am aiming for another one.
The wing to eject a high speed field. 1 or many frequencies. It doesn't matter at this point. We have everything right in front of us. Mosfets for hi speed on/off times. The clashing fields was mentioned back in October.
--giantkiller. I believe I am exhausted.
giantkiller
By having 2 loops of different sizes you have a phase shift.
By having the signal go in 2 different directions you increase the frequency of head-on interactions of the magnetic fields which equates to very high speed clashing. The gyrations are in the opposite direction by harmonic alignment.
If the 2 loops were the same size and tuned to the Shuman freq. one could see results. If the dymanic impedance can be kept stable or within a window you would basically have Earth as the speaker and the TPU as the microphone. We are pointing the microphone/TPU into the speaker/Earth to listen. That is also why when you flip it over it shuts off. But then in the new direction it can be restarted. The TPU is like having 2 microphones taped together in parallel in opposite directions. See?
And that my friends is the secret of operation. The Telsa coils gives us that tremendous push against the earths field and fires into the next one, precharging it in time with the next pulse. Whoa, baby!
The secret of the mechanics is what we are working on. The dynamics of the final step is where I am wading through. The GK4 showed all these results but not in concert. This new single wing tpu should show some control. Once again I have multiple Tesla coils inline each one running into the next one. The discharge field pushes into the next coil inline and so on and so on. Yes, this is a rail gun firing into a rail firing into a rail gun. The tuning is the process of bringing the RE discharge timing in sync with when the next pulse hits in circumferal distance of next coil on the ring. Perfect alignment equals precise nuclear alignment into a feed back generation cycle. This is the amplifier loop back to Earth. And she sings back in chorus.
Tesla coil = step up transformer. Just change the ratio or look at the expenditure of energy.
Don't know if that was what you knew already. I am just pursuing a clean firing mechanism.
joe dirt
Hey G.K.
Found a good historic reference, thought you might want to take a look:
http://www.gutenberg.org/files/15617/15617-h/15617-h.htm
decent illustrations.
Dirt
