Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
0 Members and 28 Guests are viewing this topic.
giantkiller
Posted new stuff:
http://www.overunity.com/index.php/topic,2535.msg36780.html#msg36780
" height="480" border="0 width="640"
I posted this back on February 4-2007. See any similarities?
" id="thumb_5482" border="0
More factoids:
http://www.tfcbooks.com/articles/tws5.htm
a perfect antenna actually creates an event horizon unto itself. Sounds similarly like a radiant energy short to me.
--giantkiller.
weri812
PUT YOUR MIND IN GEAR BEFORE  YOU PUT YOUR MOUTH IN MOTION
weri812
to all
ok guys after reading the last 2 days i have to ask
the first drawing is ottos  first final drawing
the second one is the  final drawing every one is using
to me they are difrent as in not the same
to me the third drawing should be the one  everyone should be using
because the three signals are in jected in to the ring from difrent angler points
these tap points will inject the signal in 2 directions at the same time.  am i wrong?
wer
ronotte
@wer,
please test the third! Let's compare the results.
Roberto
Bruce_TPU
@ wer
Please remember, if you do this to test "opposing signals", there has to be two thing, or it will not work:
A.  Identical signals (same exact frequency)
B.  Each with it's own source.  If the same source is used, it will not work.   :)
Cheers,
Bruce
