Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
0 Members and 40 Guests are viewing this topic.
Thaelin
  SICK EM  GK!  I sent them a real pissy email and was totally ignored. Figures huh?
  About WaveWatcher, posted somewhere his handle no longer works so is posting with a new one. Look in News/Bird on a wire/
should find him there.
To all:
   OK, have my fets,drivers and all. Now "exactly" which circuit am I to build?  Which is the group going with. That way I will be on the same page hopefully.
sugra
Bruce_TPU
@ gnostic
Please catch up by reading WaveWatchers posts on "bird on a wire" in the news section.  Different source is ALL the difference.  Too much time to rehash..but everything is there, and on my thread, and look at all of sugra's recent post.  Thank!
Cheers,
Bruce
joe dirt
Hello all
Tesla is right, you can get d.c. from a.c. with just windings, in the pic I have an led
hooked to an outer winding, all I did was flip the led over and nothing else.
Dirt
turbo
hi joe Tesla did also make a rectifier with permanent magnets which he used to convert his AC to DC because the grid was develloped for DC and he needed to power it from a AC signal untill the grid was replaced for use with his AC.
i also had a patent of that of it but i cannot find it right now.
Marco.
c0mster
Here is yet another excel spread sheet? I used this one to calculate the length of the secondary based on weight of the primary. It also calculates resistance. The colored columns are the or column. Fill in the weight value in the colored row to get the resistance. enter length to get weight.
Cam
