Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
bob.rennips
Quote from: -[marco]- on June 30, 2007, 01:49:31 PM
"or when they are connected in reverese of one another." (transformers)
Great to see someone working on what SM was talking about concerning transformers.
I think this could become a big topic in its own right.
What's your understanding of connecting transformers "in reverse of one another" ?
I'm thinking:
  Output of Transformer A going to Input of Transformer B.
  Output of Transformer B going to Input of Transformer A.
Assuming there is a pulse of coil A also going on. Will there be a small phase delay as the signal is 100% feedback on the original signal ?
Or is he talking driving input A and input B and connecting the output together ?
turbo
hi Bob,
i think it's more like they are connected in reverse so the fields cancel out each other between the transformers and the distance in between will show some intresting results.
i am currently working on this item.
here is a short video which shows the transformers reacting to magnets nearby.
Marco.
Earl
Hi Bob, Hi Marco et al,
I have always been a fan of repelling magnetic fields.  The attached image shows how the magnetic fields bend 90 degrees.  Another interesting property is that a magnetic black hole is formed between the two (electro)magnets.
Regards, Earl
"It is through science that we prove, but through intuition that we discover." - H. Poincare
"Most of all, start every day asking yourself what you will do today to make the world a better place to live in."  Mark Snoswell
"As we look ahead, we have an expression in Shell, which we like to use, and that is just as the Stone Age did not end for the lack of rocks, the oil and gas age will not end for the lack oil and gas, but rather technology will move us forward." John Hofmeister, president Shell Oil Company
turbo
hi Earl,
indeed yesterday when i placed two magnets in a 90 degree fashion (one horizontal and one vertical) ontop of a transformer there was some sort of intresting "scattering" like phenomena in the output signal.
it got my attention and i am going to examine it further.
Marco.
Bruce_TPU
Quote from: Earl on July 01, 2007, 10:44:13 AM
Regards, Earl
My, Earl that is an interesting bit of information indeed.  As I have said, 7.3 can only come from either:
1.  AC electromagnet(s) at 7.3 Hz
2.  Tuned tesla pick up coil/effective antenna
Someone mentioned, I think bob.R that it is interesting that all the circuits go into the middle where one would think the fields would be the strongest.  Hmmm....now you know why I want to experiment also with electromagnet(s) tuned to 7.3 Hz around the ECD with it's three frequencies.
It is either there artificially or naturaly.  Not too many experiments to find out, I believe.
Cheers,
Bruce
