Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
giantkiller
Quote from: mrl on January 22, 2007, 11:37:35 PM
Here's an idea I've been toying with.
It's a very small version of the Tesla Magnifying Transmitter.
I think this stands a good chance of pumping out RE.
I don't think we need to hit the thing with kilovolts to get it to put out RE.  It's all in the pulse duration and rise / fall time.  The inside cone winding is the collector coil.
See Attached.
These guys dropped a coil by incorporating the inverted cone with the wide loop.
http://www.hoelscher-hi.de/hendrik/english/coil.htm
I am starting to see each stage of my tpu building as being many, many ways. Just like we were told in the beginning.
I also see the Neon bulb as a replacement for a tube that Tesla had in the car ride with his nephew. Same idea just a different circuit.
Thanks. I do have a 12vdc inverter to 120vac suggested by Fatbird today.
--giantkiller.
pese
AhuraMazda
Pese,
Thank you for the links specially the one about a movie about Tesla. I was sad to realise about David Bowie playing the role of Tesla. It should have been Arnold Schwartznigar. Of course Edisson's idea of a light bulb was just a front for supplying the market with heroin filled light bulbs. Then Tesla comes along with his FE powered car and the car chase etc etc. I need a holiday!
AM
mrl
I think Pese is right.  There's something wrong with that radiant charger circuit.  The SCR is wired in on the wrong side and also I don't think you can used the bridge rectifier.
You have to follow the current flow very carefully to see it.
However, the core values are still not critical.  If it's like the Bedini motor all you need is welding wire.
In the Bedini motor (according to my present understanding) what happens is as the magnet approaches (or is moving away from it... not sure) the core it induces a current into the feedback winding, which then turns on the transistor, which then causes current to flow in another parallel winding, which then causes a counter magnetic field to form in the core, which then neutralizes the magnetic attraction between the magnet on the wheel and the steel in the core.  This in turn allows the magnet / wheel to pass over, or past, the core without any back drag.  During this process radiant energy is produced in the narrow back EMF spike (the window).  The trick is, you must adjust the bias of the transistor so that it turns on just enough to cancel out the magnetic field (equal repulsion) that is being induced by the approaching (moving away) magnet.  When this happens the magnetic field is chocked off inside the core and RE will manifest in that window.  The counter magnetic field must be at its exact equal when the magnet is a dead center of the core (or as it it just moving away from the core), thus there is no attraction (as I understand it).
You can replace the wheel by just placing a (weak) magnet right on top, or very close, to the core, or even place another coil right on top of the main core (the coil will provide the counter field ).  Once a field is formed in the core the transistor will turn on and an oscillation will start.  You don't really need to build the motor.  You just need to build the three winding core and arrange the circuit to feed back an electrical pulse to the transistor which then turns on and neutralizes the magnetic field which makes the transistor turn off, and on and on it goes.  If everything is just right you'll get the radiant pulse.  John says your waveform should look like the output of a Tesla coil.  It will ring.
This is my current understanding.  I think that (apparently faulty) circuit can be made to work if you understand how the Bedini motor works.
giantkiller
Ordered 6 samples of h11d1 opto isolators from Fairchild Direct. 2nd day UPS. $0.00 total cost.
