Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
0 Members and 23 Guests are viewing this topic.
giantkiller
I had me a brickside coil revelation. Thunk! The ECD, SM15, SM17 radiate RE across an air gap. The SM4, SM6, gk4 couples RE at 90 degrees via an array of micro-wing crossings.
I traced the wires and the parts count on the SM17 and it looks like it incorporates 2 stun guns with the large coil on the probes. That is my next experiment. I already did a 1 stun gun test with the large ez-flow loop and brought down the house. In looking at the SM15 cutaway it would stand that there is an upper & lower loop. Now what if some of those components in the photos were just obfuscations or the circuitry was 2 beefed up stun gun circuits. That would still have the blocking oscillator in it, and the large caps, large resistors in parallel, the feedback transformer winding.
Vacation was great! Showed the family them coils. I are family genius now! :D
I go back to Penna in 3 months. Gained a free roundtrip ticket for getting bumped today.
Checks in the mail (from 'The Secret').
--giantkiller.
innovation_station
some time ago i said about the flash system in a disposable camra  is that not a blocking osc? it will work on low voltage but will it produce the required amount of power to make the ring operate ?
i have one here i will take apart and play around with you just never know ;)
is
well i got the cam apart and well it is much like your stun guns gk
in taking it apart i managed to zap myself bout 5 times it is not bad but you can feel it
so i was thinking of un hooking the flash and hooking up to the coil just to see what happins i kind of think it will do the same as a stun gun but on a much lower level
so i guess i will see verry soon ;)
innovation_station
gk might there be a simple way to beef up the output of the cam flash ?
maybe send it through another small transformer? b4 the coil this runs on 1.5 volts and i felt a good enough zap from it
well in playing with this little circuit i was wondering a few more things can i change the time it takes to charge the cap it takes too long to charge it
and when i hooked up my voltmeter to the cap when it is fully charged it says it is over 300vdc
i have no idea how manny miliamps when it is fully discharged  it is around 48 -50 volts dc I should say that after it is fried that is what is left in the cap
so i will try to fire it into a control and see what the results are on my scope
ist
well
lets just say im glad i donot have a stun gun!!!!!!!
this is enough 4 me to start with  ;)
;D ;D neos were fun at the start this is kool
i could not get it to charge the cap when it was put a coil drictly so what should i put in line with the circuit to allow me to charge the cap then discharge it at my will?
i know a spark gap that way the coil can remain hooked up to the circuit and charge the cap
now this is basic stuff but it is all new to me so i share with you all it is probly not the tpu but it sure is kool and well if this is the tpu then i could see supper lighting from the ring cuz i had a oopeee and shorted out the fully charged cap and holy @#$! for sparks so no tubes just yet 4 me lol still not ready more fear than anything else  ;)
so i play this way 4 now
WOW!!!! i just can not beleave how much darn electricty comes from 1 aa battery i really encourage others to play with this too cuz wow!!!
giantkiller
In reference to:
http://www.overunity.com/index.php/topic,1872.msg45628.html#msg45628
This is the bottom line. It relates to the wing shape explanation in Ronotte's pdf. Lifters point down and are powered by Tesla coils for RE generation. The SM17 has 2 wing edges facing each other. Look deep at the pictures. The fat little coils are 90 degree coupled. The ecds point to the center. If the collectors were facing directly into each other there would a greater power out.
Basically it points to a circular winding with a bent edge at one point of the wind circumference and not the ring circumference to achieve a sharp transmission edge. We are smacking the copper faster than it can conduct with a fast rise edge of a square wave.
You can see the sloppy wing edge on the internals of the GK4. I did put alum plates on top and bottom to prove the wing edge operation in the ecd. I achieved 'Dartlets' again.
So the choice is direct 90 degree coupling or air gap coupling. Pulse with square pulses, nothing fancy. Investigate the operation of lifters too before you start.
Google: 'exploding pop can' to see high speed emmissions against aluminium. If one were to pulse a conical shape coil with a aluminium shell in the middle, you would have a rail gun or high freq matter propulsion device. If one were to pulse plates immersed in water this way you could achieve explosions. If one were the produce RE at high power you would produce magnetokinetic lift. Shift the angle and achieve lateral propulsion. Make a lifter of two rings. Inside powered by a single coil, the outside pulsed in sections for lateral movement.
Please be careful.
--giantkiller. No bs.
acerzw
Hi,
    I was impressed with the Egyptian tuning forks picture which someone put up, so I thought I would add a little contribution in the same light, now maybe this is nothing but good old Hermes Trimagistus who supposedly taught the Egyptians all the their science left an emerald tablet, me thinks he is relating something to do with the Scalar Waves and Magnetic Fields?
Maybe Hermes was the Original Lord of the Rings...
(oh and I also recommend looking at Thomas Trowager's Pyramid Device on Peswiki, 3 pictures attached also.)
In a Holographic Multiverse everything is smoke and mirrors!
What is Reality? Improve yours: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13459
A shorter version for the very open-minded: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13866
