Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
giantkiller
The multiple frequencies terminated on a common line in the GK4, the ECD, and Turbo coil show that incredible high frequencies can be generated due to phase cancellation from incredibly low frequencies.
Also, stun guns run at 6khz. Now that was something worth stumbling on. ;)
I am in the middle of testing 2 and 3 frequencies applied to my Turbo coil. When I ran 1 freq through all 3 serially connected segments I got great results. But by disconnecting the segments and putting in 2 more freqs I have change operating parameters of impedance and current draw. I am now up against the combination lock. So that is where I will be to make this next step. Got to keep from blowing up FETS.
--giantkiller.
bolt
Have you tried putting 90 volt neons across the fets to limit the voltage as used in the SSG? This may give you a little more protection.
giantkiller
But that would damp out the signal injection into the coil. I guess till I get the controls correct. The coil is wound very close to balanced mass in comparison with each segment. I drive 1 segment and I get 3x the current draw. Stands to reason. I got a bunch starter neons to spec out.
I haven't found the SSG yet.
--giantkiller.
bolt
No doubt this has been stated before but direct from "the horses mouth"  SM states "But the important thing is to wrap thecontrol coils perpendicularly around the collector coils.
There need to be three of them all the way around.
Start them up one at a time each.
First frequency then second harmonic component into the second, then the third.
When you eventually strike thecord look out!"
So it appears what i thought of today ma be correct. His big mama 800 volt TPU did use two frequencies activated by just two frequencies. There is a third but its derived as a harmonic of the 1st clock. It is NOT artifically created to produce frequency number 2.  I feel quite sure there are only 2 clocks but the 3rd is derived as a harmonic. I see many circuits here using pulses and sqaure waves. If the designs calls for purity signal then these clocks must be pure sinewave. The kick may not be produced by an EMF type kick but as a constructive wave of 3 perfect sinewaves ie an almost musical note of great purity. Thats why SM said tubes work better. Further on he says
"Most of the most successful units we made had control wiring run or wrapped vertically over the horizontal collector wires.
You can se them in the units in some of the videos under black plastic covering.
They were run perpendicular to the travel of the collector wires.
They were run in multiple segments.
each segment could be fed a different frequency individually and or from a collector section to help perpetuate the oscillation and control.
The control frequencies are important in order to make power from the collector.
I assumed that anyone working on technology this sophisticated would have a superior
knowledge of electronics and an understanding of PURE frequency output being a Necessity to
control the reactions going on inside the collector."
Mmm PURE frequency?? sounds like sine wave to me not clock pulses driven off your TTL stuff.
........more thoughts.
innovation_station
i just started reading your post bolt and i had to say look at that.......
humm..... ALL THE WAY AROUND  now why did i not catch that b4??
is
