Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
acerzw
GK,
I have two/three frequencies which might be of some use if you can generate them. They were posted in a link on the forum in another thread I think, can't remember. It seemed to be ignored at the time, maybe now is the time to dust it off. Anyway please find attached a copy of the web page in PDF format, this might be it?
Do not be put off by the mention of Tibetans etc in this document I have several very good source documents that give eyewitness accounts that verify that part of the phenomenon.
I am working on additional leads from a very unusual source, will post more soon if fruitful.
Acerzw, researcher - see you on the moon... ;)
In a Holographic Multiverse everything is smoke and mirrors!
What is Reality? Improve yours: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13459
A shorter version for the very open-minded: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13866
bolt
There are other clues but i agree frequency can be any waveform. However the TPU is known to wind up slowly and decay slowly according to SM vids. When i get around to practical testing i shall be looking for LC tank type of oscillators where the control coil is centre tapped because i seen this ring and decay in RF. In other words the TPU is almost in resonance by its own control coils.  I believe the kick does not need to come from switching the fets hard in fact  i bet SM had a 9 volt PP3 battery tucked inside some designs are running very weak LC oscillators which slowly induce the forward circular magnetic motion around the collector coils. These gentle oscillators may not even require more than a few milli amps and they shall be sine waves because this is LC.  As the system speeds up the speed of the mag wave passing around the collector coils produce the massive pulse wave NOT the control fets. Its a means to an end. I see it as parasitic oscillations being induced on the collector to emulate a mechanical wheel. The construction of 2 LC oscillators are providing the control to the system and its very easy to pick the second harmonic of the LC and feed it one segment ahead. The 3 frequencies are very weak in themselves but collectively they create a constructive wave pushing the mag wave around the collector coil.  These spikes will happen when the right frequencies  are hit and the collector begins to accelerate. The other control coils will use the pulse which has been collector produced NOT by the fets and feed that to the gate of the next segment for timing purposes only. As the system speeds up the trigger pulses provide phase control of the oscillators in other words phase locked loop.  With the right combination the perpetual motion should be set up of course we dont know what that is yet. As SM has stated we must detune the Q of the system because when the PLL is bang on correct the circular RE racing around the collectors will cause a meltdown so the effectively  of the control PLL is detuned to harness the power. The over winding of all three coils collect this energy as the output.
Of course this is my take on the TPU and till we can reproduce it then it just the passing of ideas.
I believe its very much akin to the SSG. When we look at any conventional electrical generator the action of coil and magnets passing each other produce a sine wave AC output not a square wave or pulse. Likewise with SSG i am assuming the voltage rises and declines as the magnet passes the coil except the collapsing field produces this peculiar RE kick which is collected AFTER and as not produced by the control fets themselves so we should not be attempting to produce this kick because it will come to us later as an artifact.  They are only used for timing purpose and the diode prevents the real electron flow. With TPU i believe we are attempting to reproduce the SSG physical wheel and we should NOT be looking at producing the actual pulses. So the control to emulate an SSG wheel would be sine wave not square or pulses.
Thaelin
Hi Acerzw:
   I posted this some time ago and was asked to remove it as it did not relate. It is refering to sound waves and not rf waves so I guess that is why. Sound mixes different than rf but both are still "waves".
thaelin
Quote from: acerzw on September 03, 2007, 01:05:42 PM
GK,
acerzw
@thaelin,
I understand what they were saying but I do think that as the document says, the ratio of the frequencies are more important than the actual frequencies, and a conversion of some form could no doubt be computed if necessary. I do suspect that there are clues within it, but also note that the frequencies referenced within are in the range that a TPU can use. The harmonic mentioned is spookily close to the TPU's and also note that the frequencies are slightly off which is what is used in a TPU in order not to melt down in a full conversion event.  I would not underestimate the importance of this document as it refers to a verified phenomenon, which I have been aware of for 18 years and have never seen published frequencies for. it was truly a great find by you, thank you very much for finding it. Hence I have attached it yet again for emphasis.
@acerzw, researcher
z_p_e
Bolt,
You present some good ideas there in your last post.
Keep pursuing it.
I once had a theory too that LC tanks were used in the device, as this is the only way I can think of creating an electrical analog of "inertia". However, these tanks would have been stimulated with pulses.
Cheers,
Darren
