Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
0 Members and 41 Guests are viewing this topic.
giantkiller
giantkiller
Transferring from another site posted by jd0300.
OK EVERYONE
I'm making this easy for everybody! I copied the page, ran it through the translator (still preserved the pictures thankfully), and uploaded it to this post...
THIS PAGE HAS SO MANY COROLATIONS WITH MR. MARK'S EXPERIMENTS!!!
The article talks about two transformers that are 180 degrees out of phase with each other.... DC OUTPUT ON THE SECONDARY SIDE!!! It's all here... Check it out!!! I'm still reading it as I'm posting here.... and It just so happens that I have two identical transformers to try the tests out with....
Oh but here's the kicker.... look on the graphs to see what frequencies the author got these effects..... 3-6kHz!!!
God Bless,
Jason O
sonny
thanks Giant, looks like the sports model ;D
Moab
Ok guys
Heres the setup 3. 4'' coils 60 turns primary 2 in parallel #30 AWG. 4 segments @90 degrees 22 AWG 60 turns in series, all copper with the middle coil open and used as the collector. Only the top and bottom coil are powered 4.5V smooth DC@ 25 watts in @approximately12 KHZ. I am getting 99 volt DC spikes on the scope at just over 4 KHZ and a rotating field that is vertical and counter clock wise. I know this because i used a compose to verify rotation.How ever the thing that really gets me exited is what happens when a neo mag is dropped in to the coils when powered. They are violently thrown from side to side and top to bottom of the coils and seem to be held inside the coils by the magnetic field with in the coils themselves while these neo mags are being pummeled, the voltage spikes on the scope are over 300 volts. I still cant manage any usable power but it is interesting. (As in no lighting a bulb). I have kicks and a rotating field and 300V DC spikes. Now what G.K ? ::)
giantkiller
@Moab,
Congratulations on acquiring kicks! Your results are better that mine with the slight change in construction. Impressive and welcome to the club.
If you could draw out a diagram and post it. The differences are of great importance. This validates the 'Many ways to get there' postings.
This continuing saga connects to the following:
http://www.overunity.com/index.php/topic,1910.msg22220.html#msg22220]
--giantkiller. This is the next step.
