Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
AhuraMazda
I have been keeping an eye on all the achievements on the TPU. You all get top marks for perseverance but the image from EM sum's up the reality of what truely is happening.
Maybe you should look at these for a view of what are the basics:
http://www.youtube.com/watch?v=eqjl-qRy71w
http://www.youtube.com/watch?v=1bUWcy8HwpM
AM
P.S. EM, Sorry for adding more to the pot!
bolt
Interesting but there are some very smart guys on here that live and sleep math but it hasn't helped make a TPU in the last 18 months. Maybe a taxi driver will end it making one.
I also meant to say these 2 or 3 frequencies has so much confliction. Why does the big TPU have only 2 baluns and not 3? Why does the first prototype only have 1 on top. Why do the middle range tpu have no visible baluns?  Why does the small open frame tpu look to have 2 collectors top and bottom and not 3?
I got a headache off to bed.
EMdevices
Thanks for that link AM,Ã,  I watched the first video and enjoyed it.Ã, Ã,  I saw this demo years ago in one of my physics classes, very interesting how it works.
Here's something else to think about guys, if you want to pursue the Schumann thing.Ã, Ã,
1)Ã,  Take two coils of EQUAL lengths.
2)Ã,  Take two capacitors of EQUAL value
Now you have two resonating TANK circuits of EQUAL frequency.
3)Ã,  Start to cut one of the coils small piece at a time, untill the resonating frequency is off by.... you guessed it.... 7.3 HzÃ,  :)
Then, the tank circuits will be exicted by the natural magnetic Schumann resonance, but feed one output to the other for some additon of signals and feedback, the output might just go through the roof !!
EM
innovation_station
hears a thought i had and im sure others too
for the feed back use easy flow audio wire use the copper part of the coil for feedback to the coil and use the siliver part of the feed back for output!!
the coper will be much slower and lower voltage  than the siliver  we only want to "kickstart" the coil im sure we will need a resistor from the copper of the feedback  to the input to slow it down more
ist
bolt
Worked out the answer now the reason is the number of baluns is = to the number of collectors. The more collectors you have the more you can put them in parallel to increase the current or series to increase the voltage. The first model had one collector and one balun. The baluns are absolutely critical together with the magnets. If you don't make a balun you cant split the load to provide impedance matching and phase shift and the loop will never ever work. All collectors must be of the same size and resonance.  They are simply put into parallel to increase current handling but that can have other effects that need to be controlled. There must be a space between the collectors so cant sit one on top of the other. Thats why the 800 volt tpu is tall.  The 2 ends pass through the balun to the sig gen box which is terminated by  resonance cap. The secondary side of the balun connects 1st control coil only and primary side connects to the sig gen PA. The ratio of windings is critical to ensure phase and amount that is fed back to the loop. As the first control coil is injected with the right sine wave frequencies a part of this input is directed into the main collector and another part is sent to the first control coil. The oscillation is sent around the loop and back again but the control coil will prevent it returning on this position coil. The next harmonic is already sent out which is now ahead of the 1st control and speeds up the returning back wave. The 3rd harmonic is sent ahead to the 3rd coil which gives it the third boost. The process continues at control 1. So now we have a cold electron flow circulating the loop which is also cut to resonance.  It important to realize that the sig gen box does not really participate after the first few seconds. When the frequencies are correct it will automatically into forward gain positive feedback. NOT back to the sig gen but on to the next control coil. This TPU will run itself just before it explodes and switching off the control box will not stop it if allowed to get that far. SO the harmonic of the second coil will arrive there twice as fast as the first one because the frequncy is higher and the wavelength is shorter. The use of three frequencies produces standing waves that exact math relationship to the size of the collector.  In this concept there is no need for spark gaps, square waves and spikes. It appears to me so many went wrong with this making Bedini Coils with mosfet spike triggers and nothing could be further from how this works.
SM has very nearly spilled the beans on this risking his freedom and pay packet. He is right he has said far too much already. SM mentioned Bushwacker and Freedomfuel for getting close. Bushwacker dedicated most of his time working on the Hope device. IMO it will never work he is only making a cooker peizo coil but he was named because he was injecting AUDIO sine waves into his hope device. However the guy reads like a crank to me every post was about abductions and threats  from MIB  which i very much doubt they would be interested in his cooker coil. Freedomfuel was mentioned because of his excellent theory. He was bang on correct about how this works but for some reason i recon he saw the potential good and BAD and decided to walk away. But he deleted over 100 very critical posts and was leaps ahead of most other on here 12 months ago. For all i know he has a working model.
