Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
dutchy1966
Quote from: bolt on September 15, 2007, 12:21:39 PM
Worked out the answer now the reason is the number of baluns is = to the number of collectors. The more collectors you have the more you can put them in parallel to increase the current or series to increase the voltage. The first model had one collector and one balun. The baluns are absolutely critical together with the magnets. If you don't make a balun you cant split the load to provide impedance matching and phase shift and the loop will never ever work. All collectors must be of the same size and resonance.  They are simply put into parallel to increase current handling but that can have other effects that need to be controlled. There must be a space between the collectors so cant sit one on top of the other. Thats why the 800 volt tpu is tall.  The 2 ends pass through the balun to the sig gen box which is terminated by  resonance cap. The secondary side of the balun connects 1st control coil only and primary side connects to the sig gen PA. The ratio of windings is critical to ensure phase and amount that is fed back to the loop. As the first control coil is injected with the right sine wave frequencies a part of this input is directed into the main collector and another part is sent to the first control coil. The oscillation is sent around the loop and back again but the control coil will prevent it returning on this position coil. The next harmonic is already sent out which is now ahead of the 1st control and speeds up the returning back wave. The 3rd harmonic is sent ahead to the 3rd coil which gives it the third boost. The process continues at control 1. So now we have a cold electron flow circulating the loop which is also cut to resonance.  It important to realize that the sig gen box does not really participate after the first few seconds. When the frequencies are correct it will automatically into forward gain positive feedback. NOT back to the sig gen but on to the next control coil. This TPU will run itself just before it explodes and switching off the control box will not stop it if allowed to get that far. SO the harmonic of the second coil will arrive there twice as fast as the first one because the frequncy is higher and the wavelength is shorter. The use of three frequencies produces standing waves that exact math relationship to the size of the collector.  In this concept there is no need for spark gaps, square waves and spikes. It appears to me so many went wrong with this making Bedini Coils with mosfet spike triggers and nothing could be further from how this works.
SM has very nearly spilled the beans on this risking his freedom and pay packet. He is right he has said far too much already. SM mentioned Bushwacker and Freedomfuel for getting close. Bushwacker dedicated most of his time working on the Hope device. IMO it will never work he is only making a cooker peizo coil but he was named because he was injecting AUDIO sine waves into his hope device. However the guy reads like a crank to me every post was about abductions and threats  from MIB  which i very much doubt they would be interested in his cooker coil. Freedomfuel was mentioned because of his excellent theory. He was bang on correct about how this works but for some reason i recon he saw the potential good and BAD and decided to walk away. But he deleted over 100 very critical posts and was leaps ahead of most other on here 12 months ago. For all i know he has a working model.
Hi Bolt,
Thanks for the drawing. That helps!
I still have some questions:
Why do the two ends pass through the balun?
So every control coil is not fed seperately?
Regards,
Robert
bolt
The collector is a loop antenna and we need the balun to pass the right amount of signal into the loop. If you look on the 800 volt tpu you see 2 white wires are the collector passing though.  The coil is fed the other 2 are linked to it directly as shown. The harmonics will reach the others when they get there.
tao
.... the ends go through the balun ONE turn. The balun is a ferrite ring, not plastic brass wood or a chocolate cookie.
HAHAHA...
Gothic
I don,t know,   maybe I,ll try it.
leeroyjenkinsii
Is anyone getting any useful energy out of these yet?  Have you guys gotten to the right setup?
