Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
HopeForHumanity
Looks like the videos are processing....
The lurker waits! 8)
Ron Paul is internet overunity: http://www.youtube.com/watch?v=vXnBZd4nyWk
WE MUST STOP THIS! Free energy is being surpressed because of it!
bolt
btentzer sorry there isn't a schematic. No one knows for sure till its working at this time only an experimenters frame work which might open new possibles and i have already outlined this in my recent posts and sketches. Basically you need to make a big enough tpu to work comfortably inside the loop. You need precision frequency generators, very high slew quality op amps with DC to 1 Meg+ mosfet audio amp for sine wave work.   I strongly suggest you make a 2 collector tpu with 6 control coils ie 3 for each, 2 baluns pre wound with 3 windings of 50 turns each per balun ready for testing all combinations. This will be how i would proceed and everything else is test and learn and record wiring configs of control coils etc.  The first stage is find strange heating effects or large spectacular waveforms showing up on the scope when at least 3 control coils are injected. Then try 6 controls over 2 collectors and see what happens. Try adding diodes to each, changing the collector capacitor etc its all trial an error. Eventually there will be power if this has any chance of working. When there is power then work out how to configue the balun to inject a portion of the power back into the loop. Change windings, cross them twist a bit, add caps, diodes etc to see if it needs to be siphoned off. Once we get feedback from a coil already showing powerful signals then overunity should come next but there is still many weeks/months work to do yet.
So in the meantime tubes is rather like asking me to make a Linux version when i don't even have an idea of the windows version yet and its been some years since i touched EL84's EL80's and EZ80's tubes etc. but i have to agree tubes are nice IF your used to working with them and have plenty of experience  which probably makes you least 45+ years old. For younger people then i see no advantage as the finished TPU is going to be SD's anyway so you might as well get used to each quirks.
Grumpy
and where is this "power" coming from again?
Why would SM have two baluns in a three-collector ring?  Perhaps two baluns equals four control coils.
        -Frank Edwards
bolt
you KNOW where this power comes from;)
I don't know if there are any 3 collector rings. I haven't seen any evidence of that yet. All the early models are 1 collector 1 balum, Later models are 2 balun 2 collector including 800 volt tpu.  All the extra collectors do is very simple
1) Add more current capability by placing them in parallel.
2) Add more voltage when in series.
Grumpy
Stop the damn half-cocked BS until you at least read SM's letters to Mannix.
SM said three collectors!!!  NOT TWO!!!
If you don't see anything with one, don't bother going to three.
How do you know those "balluns" are just toroidal transformers stepping up voltage.
As for where to power comes from - it was concluded about 2 years ago that SM was not positively sure that it came from the earth's magnetic field.  If the TPU was a device after the work of Tesla's RE, then SM would know that it was RE being utilized.  If the devices were using the Schumann Resonance's then SM would know that too.
        -Frank Edwards
