Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
IronHead
High grade car audio power cable ,maybe 8 gauge .
More than 700 strands of zero oxygen electronic
grade pure copper tined all the way through.
Buck a foot for KICKER  hyper flex wire.
Just a thought
mrl
Quote from: otto on January 07, 2007, 05:11:49 AM
Hello all,
sorry guys I cant be quiet!!
Did you ever ask yourself why we have NO POWER in our coils????
Where is the POWER???
Why cant we make even a 40W light bulb to light????
We feed into our coils 1 or 2 or 3 or even more amperes but nothing. Where is the Power gone???
The answer is in the wave (kick)!!!! You know, a wave (kick) is a very, very powerfull "Thing"!!
Otto
Well ? from what can see, if your pulse is a grounding pulse then it will do nothing.  However, if you pulse is a positive pulse then all you're doing is shoring out the coil to the plus side of the supply.
So, let's see.  Since the light bulb is lit this means that there's a magnetic filed formed in the coil.  When you short out the coil you will generate a pulse and when you let the coil charge back up you will also get a pulse.
This could work to your advantage.  Hard to predict the results.
giantkiller
Quote from: CTG Labs on January 07, 2007, 01:15:27 PM
I don't know that GK has claimed any OU in the form of heat or otherwise.  I was just asking him to perform this heat test if he can, as iron wire will get hot easily, its not really meant for circuits, its meant for tying plants up in the garden!
So, am waiting his results!
D.
To you and Pese. If I had used copper core my field generation would have been more dangerous? I made the next mistake for lack of control then. So let's backtrack. 555 drift, iron core, cheap pots. I feel like Alexander Graham Bell. These mis-doings were a true blessing. By using copper core now then there would be a greater field with less control. And the inverse would be better control with field limitation. Tesla used copper. Mannix said 'Don't change anything'. Maybe implied control till the freqs get figured out. And what I did is a great test platform for to play with. Just think how battered our faces would be if we ran before we crawled.
I agree with our speed of trying.
--giantkiller.
Gearhead
Quote from: CTG Labs on January 07, 2007, 04:45:59 AM
"Hello Dave,
I hope you and a few people with scopes will make the little test.
Make just a little coil.
Wind over your 2 fingers 50 turns of thin wire. Diameter is NOT important. Then connect one end to +12-13V. The other end to your MOSFET to pulse this coil.
Through this coil put a wire and connect it to the end of your coil where you pulse it. Now you have 1 end open. This end of the wire connect to a light bulb and the other end of the light bulb connect to minus.
Waiting for your results!!
Otto"
This is very similar to an automobile ignition system.  A twelve volt coil is pulsed by a set of points or electronically.  When the magnetic field collapses into the inner coil the voltage is increased from 12 to maybe 15,000 volts and is able to fire a spark plug.
The difference here is that the inner coil is not coiled but a single wire.  Hopefully the TPU uses resonance to increase the output to ou.  If it will not do this we have a dead end.
CTG Labs
GK,
I agree, if it helps to reduce the effect, ie let you see it, but less dangerously then thats good.
I think what we are saying is that is heat generation in iron wire odd, no?  Is the heat generated, more than the input power?  Waiting on your test result.
Just wanted some clarification on what has been discovered because heat in a coil is expected isn't it?  Without some temperature and power readings how do you know what you have is odd?  I mean 12v at 3 amps, is going to make some heat?
Forgive me if I missed anything where you already covered this.
Best Regards,
Dave.
