Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
0 Members and 28 Guests are viewing this topic.
AhuraMazda
Quote from: innovation_station on March 26, 2007, 04:18:06 PM
NOW LEAVE ME ALONE!
Don't get paranoid. Just get yourself a descent virus scanner + firewall.
AM
starcruiser
Guys,
The TPU is a air core transformer and more, what do you think you get when you use more than one layer (2 or 3) the control coils will interact as transformers. Those who have their TPU's can verify that. The action we are looking for is the radiant energy and its conduction or transformation into usable power.
Capacitors are a requirement here since they can transform RE into usable power, they are our converters. The trick now is to efficiently create the circumstance in which to generate RE, thus we look to 90 degree coupling of the control coils to the collectors which can only allow RE to be received, thus these are our collectors.
The debate rages on as to what is the control coil configuration??? Two coils, three? maybe more. We know we use these coils to generate the event that creates our RE, the question I have is since it must be magnetic so then how might we increase the efficiency thus reach the OU or at least unity.
I was pondering this and was reading John Bedini's thread on Yahoo and he was talking about using super pole magnets to increase his efficiency of his window motor. He states it creates a sharp field and the magnet configuration produces a magnified output by 4 times its normal strength, he makes them using 2 magnets super glued together with their poles facing N-N or S-S. You may want to read on this latest info at the mention group.
I figure using this super pole magnet arrangement used on the control coils may help us out. Something was also mentioned about using another  magnet to perturb the super pole placing it along side the junction or plane of the magnetic field.
Any thoughts on if this would work?
Regards,
Carl
giantkiller
Quote from: starcruiser on March 26, 2007, 05:58:20 PM
Guys,
The TPU is a air core transformer and more, what do you think you get when you use more than one layer (2 or 3) the control coils will interact as transformers. Those who have their TPU's can verify that. The action we are lookin for is the radient energy and its conduction or transofrmation into usable power.
I was pondering this and was reading John Bendini's thread on Yahoo and he was talking about using super pole magnets to increase his efficiency of his window motor. He states it creates a sharp field and the magnet configuration produces a magnified output by 4 times its normal strength, he makes them using 2 magnets super glued together with their poles facing N-N or S-S. You may want to read on this latest info at the mention group.
And the TPU/kicks would act as the dc motor in the circuit.
--giantkiller.
Motorcoach1
Heres my toughs on the coils : have been reading about the kicks and found that interesting . The coil size is important , it depends on the size of the TPU - the coil is tuned to collapse and charge the capacitor , this means the coil is large enough to pull the electrons through the wire , but strong enough to charge the capacitor. in looking at some of the coils on the rings i feel the coil is to long.  the scenario is like the Pentium balls when one ball hits it sends the shock wave through the next three ball and the 5th ball goes in to motion (kinetic energy). in the coils being so long the magnetic Field is doing the same thing went it springs back into position a kick occurs , this is from over lapping Fields of the coil. so its bouncing back and forth trying to get its natural space back in alignment. when wrapping the coil test wrap in tight and narrow and test the capacitor that it will be used with - a big coil may be to much for the capacitor , rule of thumb is wrap the coil 20 percent over the rating , this way you know it will get a charge (with out the resistor if used) . the narrow wrap will give the other coils space for there Fields with out over lapping the critical Field. when you make the coil test the largest to energies the capacitor then start unwinding it to the minimum to energize- count the winds and then put back on the 20% you removed . just watch the over lapping Fields.   thanks Mike
simonmagus
this is compleat bs you rebooting my comp all the time and my wirless router you have played more than enough games with me im just a little nobody leave me the hell alone i have done nothing to you
Calm down, there is a likely explanation for your computer problem.
You may have a Sasser Worm infection(harmless but annoying) if you have Windows XP and have not applied Service Pack 2. To check your system info, Go to 'Start->Control Panel->System'. It should list the service pack if one is applied.
To get the lastest Windows updates go to Internet Explorer, click on 'Tools->Windows Update' and follow the prompts.
If your computer is not the only device that reboots itself , there may be an electrical problem.
