Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
innovation_station
giantkiller
Welcome back my friends to the show that never ends,
we're so glad you could attend,
come inside, come inside...
Come inside the shows about to start,
guaranteed to blow your head apart!!!
Quote from: giantkiller on March 27, 2007, 10:14:30 PM
What is up with this?
swiping magnets, transformers that match.
Stun guns connected together?
I bypassed the stun gun trigger with a TIP41 NPN tranny.
--giantkiller.
I looped the stun gun output back to the tranny base, triggered it and what do you think happened? You are correct. I had a triggered loop! The stun gun fired itself then blew. No surprise here, right? It gets better.
The stungun works off of a 9volt battery. I can now drive the stungun with a 555 timer or better yet I can drive a TPU with a 9volt battery. Amazing. Read on...
The stun gun represents a segment in each layer of the TPU. We just happen to have 4.
Now lets replace each stun gun with the flyback circuit I posted earlier:
http://www.overunity.com/index.php/topic,1872.msg26692.html#msg26692
One fires the next. Let's call them cannon balls. Everybody with me here?
String theses components in a loop and you have a cyclical cavitation chamber. Cavitation as described by Dale Pond. This can get very large. To start this infinite loop we use a Bedini magnet pickup on one of the trigger inputs to catch the magnet swiping. This component can be placed in any of the trigger inputs in the loop. We only need one.
The tuning comes in as a delay component to keep the triggering in sync with the impedance of each control coil. You want the collapse to be free and clear of any interference. <50% duty cycle has been what we have found best in producing kicks. Dudes! Surfs up and we caught the big wave!
The collectors are iron wire which creates the core for each segment. The layers rest on an air core. The picture shows four vertical collectors per layer. These are really connected together horizontally in each layer to form a single path of conduction. Everybody with me here?
Caveat: More and better details are forth coming from other sources. I wanted to clear up any miscommunication from the previous posts. Did not mean to sound cryptic. The team work was being done as I posted.
Once again, all the kick and trigger circuits look the same. Diode-cap-coil, diode-cap-coil. There is always a voltage multiplier present. Stun gun, flyback, Bedini motor circuits equal kicks which are the precursor to cavitation.
JDO300 got some beautifully huge spikes and ringing on the back end of a square pulse the other night. This equates to more cavitation. The current circuit kept running while the input current and voltage disappeared from the meters. Can you OU? I can! Man, We are psyched! diode-cap-coil, diode-cap-coil, diode-cap-coil, diode-cap-coil.
The TPUs are handheld, open flyback transformers / cavitation chambers. We got to be out of our minds! The exploding/imploding tv is a random Hutchison effect event. The results are the same, no? Think how big the cavitaion event was at the Philadelphia experiment. Everything is now possible.
Things are moving fast. We will be finished by 20070415. You can bet on it.
For the team and to the team: All for one and one for all!
--giantkiller. Hence the name.
Jdo300
Hi everyone,
Yes, GK, rosphere, and I were up last night doing some ?proof of principle? experiments to prove some of the basics for the control circuit. I will create a nice circuit diagram of the setup along with scope shots and data to post later tonight when I get home from work.
GK and all: There is one important detail about that small monitor transformer that we all missed. Notice that it has four coils wound on it, not two? Not sure what this means? Here?s something to jog your memory:
QuoteI originally got the idea from electron circuits which use vacuum rectifiers like the 5U4 GB or 5AR4 etc.  The plate has a high voltage potential with lots of usable power available. You can?t get to it or use it for anything without applying a heating voltage to the cathode or what is the cathode potential of the tube. So, you put in a small voltage of 5 volts AC 60 Hz which heats up the cathode and welcomes the electron stream from the plate (actually the other way around, but not important for this example of my thoughts). Now the high voltage power goes through the cathode and travels through the coils of the 5 volt transformer along with the 5 volt AC. If the plate voltage is not rectified then it is AC with a potential 60 Hz frequency. That combines with the 5 volt 60 Hz in the coil of the heater transformer and generally amounts to nothing. In fact the power of the 5 volt transformer amounts to nothing. It is an insignificant power supply except when the two transformers get slightly out of phase with each other, or when they are connected in reverse of one another, you can measure all kinds of things going on. You can generate all kinds of hash and multiple frequencies, and I do mean all kinds. What I measured during this process was very interesting. All these frequencies occasionally met at the same time with a much larger kick at the output.
Check out the diagram below. This isn't my completed idea but build this, measure across the resistor, and see what the output looks like... Just as Mr. Mark said, it can be very revealing...
More to come?
God Bless,
Jason O
innovation_station
Jdo300
Hello All,
I should make a correction about that circuit diagram I posted. According to GK, the small transformers he pulled from his monitor only have four leads coming out, so the two coils are attached internally. Not to say that this applies to all the transformers that look like his but just something to look out for.
God Bless,
Jason O
