Thanks to ALL for your help!!
STILL NOT ONE PERSON HAS TAKEN 1 MINUTE TO TEST THIS WORLD CHANGING PROOF?!?!?!
Started by aether22, December 07, 2020, 11:01:53 PM
aether22
Quote from: ronotte on December 16, 2020, 08:14:16 AM
Hi Aether22,[/font]
[/font]its lot of time that for many reasons I am outside FE so this short note is only a tribute to your willing to show here something that nonetheless does exists and is coherent with energy that pervade all. In effect I am practicing with radionics since a couple of years with discrete achievements and I discovered a whole new world ready to experiment with.[/font]
[/font]Note: Hmm... this is a rather potentially dangerous ground as radionics can be used for both good and bad purposes I did an error ...and very soon suffered for it![/font]
[/font]So, I am happy to shortly detail here one of many rather unusual facts I assisted and replicated easily...you can do/use it the same without big problems just like the special pics you show (Yes, I feel something but only after printing them).[/font]
[/font]So, just peek a small piece of paper and draw, using a standard pencil (pencil is important), the outline of a battery showing: name, voltage and polarity. That is all.[/font]
[/font]Well, after that, try to measure the voltage putting the tester leads over the polarities: of course, you do not read anything even with tester set to highest available sensibility.[/font]
[/font]Here comes the added value. I have put the paper over my BerkanaLab 3 dials radionic device input plate and found the balancing rate while applying my focused intent to charge the battery (it took about 3 minutes). After that I moved the paper over the output plate and left it for about 15 minutes.[/font]
[/font]Then I removed the paper, put it over the table and measured, as before (in mV range), the eventual presence of a voltage. Believe it or not...but I measured relevant voltage ranging between 20mV and 200mV. I was stunned and repeated many times the measure obtaining the same result. I found out also that such a voltage existed for more than 1 day.[/font]
Comments are appreciated.[/font]
[/font]
ronotte[/font]
Interesting, even more so in light of the fact that I have been investigating the work of William A. Tiller and his foundation.  (check out Tiller.org)
What he has scientifically proven is that electrical devices can become conditioned with human intent, he sells a device called an UED or Unimprinted Electronic Device, then 4 meditators imprint on the device and then the device conditions space around it to produce the effect the meditators sought to imprint, it is then termed an IHD or Imprinted Host Device (which they also sell but at more than 10 times the price).
He claims that the coupling between the subtle and material worlds occurs with what he terms "Deltrons" which come from a level of emotion which he says is 9 dimensional, that when these deltrons are present a coupling occurs as deltrons act as a bridge between the two.
I find your claim very interesting, alas I am not sure I could get a stick with radionics, I'm not great at tuning dials, but I think there is an important pint here.
Stubblefield and Moray both tuned things in a manner reminiscent of radionics.
Intent (not just intent but coherent meditative connection) could VERY WELL be one missing component both many replication attempts.
I have heard of other cases of this sort of thing, Joe Champion had a device that included a biological component that he claimed could do just this, make things work including Free Energy devices.
I'm really not looking to focus on the intent/spiritual side of thing, but it DOES connect with this aetheric stuff and likely would be the fastest way to get results.
I am hoping however to figure out how to get results without the need for any "special sauce", without any operator input, but I have long wondered if that is needed.
aether22
Quote from: stivep on December 16, 2020, 11:59:15 AM
Sorry  I didn't go to the rest of this nonsense:
______________________
Wesley, did you try the images?
The images aren't magic, they aren't about psychic mumbo jumbo, they aren't about radionics.
Light can push on matter, cut and burn matter, and possesses a tiny gravity field according to conventional theory.
Light and elecromagnetism can affect the vacuum according to convention (the lamb shift is an example of this, where
virtual positrons and electrons affect electron orbitals).
https://www.youtube.com/watch?v=g20JZ2HNZaw
The images affect the vacuum, you might be able to feel their influence, please give it a shot, at least a 50% chance.
And this is related to Free Energy I assure you, I can prove to a compelling degree through correlation rather powerfully.
From  article quoted in first link  of aether22:Definition of Energy and its forms:
https://www.britannica.com/science/energy
https://en.wikipedia.org/wiki/Energy
Conclusion:
-If feeling is taken in frames of physically progressive  technical benefit
Than Unspecified  forms of energy can be discussed but  discussion  outcome is based on feeling.
And feeling should be supported by  science  and likely not by God/Gods or Fairy Tales
if we expect resulting physical progress.
I Fully agree.
I didn't get into this to go into woo woo new agey spiritualist stuff, I am not found or comfortable with that.
I don't meditate, I am not religious, I have no real experience of anything spiritual and I am not away with the fairies.
I DO however acknowledge that there is evidence of various things, I have experienced what is termed a Mandela Effect flip-flop
that left me convinced of the reality of the many worlds interpretation, and I am sure that there are some real antigravitational
craft that are termed UFO's, whoever they belong to, not that I find that a straight forward subject.
I am clear that sometimes extraordinary (paranormal) things DO happen outside of regular understanding, and sometimes
consciousness plays a part.
This phenomena is real, people have felt something from coils even when they knew/expected nothing and the coils were hidden.
Bridging from the subtle back to the material if indeed the challenge, and it is a challenge I have been reluctant to explore because I can rapidly advance with images but slowly progress with physical designs even though the only results will occur with the physical version.
If you can feel the reality of this phenomena, then listen to me and I will tell you how to tweak experiments, how to add elements that can enhance this phenomena in a design.
This increases the chance or magnitude of positive results.
This isn't a game, this is the result of 26 years of dedicated research, this is serious, and the techniques don't take much to implement.
I am not asking you to build a specific device, just tweak a design you already have on the table.
If you could spend 20 minutes tweaking something, not making it any less likely to work based on conventional principles, but making it dramatically more effective based on aetheric principles, wouldn't that be time well spent if it has a chance at producing some interesting result?
aether22
Wesley, consider also that electricity began as a funny sensation on the tongue when you put dissimilar metals on it together.
It would later be found to make frogs legs twitch and move a needle.
But consider how these feats could be viewed at the time by skeptics, the sensation of the tongue could be the placebo effect, or just a "taste" or what metals feel like.
The needle moving could be a gust of wind, a silk thread or someone manipulating a magnet nearby or maybe some geomagnetic anomaly.
And a frogs leg, it's trickery or witch-craft, something straight out of Mary Shelley's Frankenstein, or maybe it is just a twitch that some dead things do like eels?
There were no meters for it initially, it's effects were subtle, it was not understood for a rather long time.
It is only with paying attention to this phenomena that it was developed into a science with meters and math behind it.
How long, how many times did people ignore the tingle on the tongue as a mere curiosity, failing to recognize it as a force that could transform the world beyond previous imagining?
The scientists also wouldn't look into Galileo's telescope!  I feel that same resistance from people!
stivep,Good Morning !
                                                    soul walking   anda-luz(i)a  (en)light walking
https://en.wikipedia.org/wiki/Damascus                                             https://en.wikipedia.org/wiki/Silves,_Portugal
        ANDA- Lusitanian
                              Wesley,do you know,do you believe in Aristoteles and Pitagoras their importance in Science and
        Philosophy
                                             during https://en.wikipedia.org/wiki/Hellenism_(religion) and today ?
                                            Also in  Israel,before becoming later roman "Protectorat Palatina" :  350 -300 a.C. ?
                                           Why also Israelits/Samarians and Judaeas visited Delphi and other Orakel localities ?
                                                            Hellenism,geophysical space  : believe and science ?
                                               Massilia/Marseille Gades/Cadiz  Troya/Peninsula Setubal/PT .... Hibriden
                                              https://translate.google.com/translate?sl=auto&tl=en&u=https://de.wikipedia.org/wiki/Atlantis
        heaven and hell
aether22 :
there is the expression "Windschatten(1:1 translation : windshadow)/slipstream" and LICHTDRUCK (1:1 translation : Lightpressure)/collotype"
collotype,Art : https://en.wikipedia.org/wiki/Collotype
"collotype" as Radiation Pressure,Physics: https://translate.google.com/translate?sl=auto&tl=en&u=https://de.wikipedia.org/wiki/Strahlungsdruck
engravar,Gravity "Magnetpressure": Lloyd Crump, US2848748
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=6&ND=3&adjacent=true&locale=en_EP&FT=D&date=19580826&CC=US&NR=2848748A&KC=A#
For SCIENCE + FICTION to REALITY AUTHORS :
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=&IN=erich+mehnert&CPC=&IC=&Submit=Search
specific : LICHTDRUCK / Radiation Pressure
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=49&ND=3&adjacent=true&locale=en_EP&FT=D&date=19980813&CC=DE&NR=19705247A1&KC=A1#
https://en.wikipedia.org/wiki/Prometheus_(2012_film)   not also a "gold-sailfoil"drive-spaceship exposed ?
Sincere
OCWL
aether22
Hi Aether22,[/font]
Hi, great experiment, watch this: https://youtu.be/nddOzPtNH30?t=4198[/color][/font]
I am thinking that the Tiller UED which is some eeprom chips could be combined with my tech, with the radionic method you discovered to really tune into something powerful.
I don't have money to do this, but if I did it would be what I'd do to as close to ensure results as is possible.
Actually since you can pay for them to condition an UED (Unimprinted Electronic Device) so it becomes a Imprinted Host Device or IHD and being that results are basically certain to breach conventional physics, results could be guaranteed!
A radionic device used to program a UED might mean one person does as well or better than 4 meditators typically used to condition a UED.
