Bullet blimp.
Started by synchro1, March 02, 2021, 08:26:34 AM
synchro1
All we need to do to test bench this aircraft is plug two seperate wires into the wall outlets and reverse them. One for the inner starter coils and fan and the other backwards to the counter rotating can. Sawing the fan blades off will act as a rotating wing. We need two ceramic bearing collars to mount the fan hub to the outside and the fan inside.
synchro1
Four times the lift for twice the power could drive itself as an overunity pump from a wall outlet simply by lifting and dropping a weighted pump handle!
Time to pay a visit to the appliance repair shop.
synchro1
Below we see the ring fan and a patent for a VTOL using the concept.
Quote from: synchro1 on March 11, 2021, 08:35:36 AM
        let remember me :
                              (https://overunity.com/833/hilden-brand-magnet-motor/dlattach/attach/5493/)
                                                        "Double the flux lines four times the force "
synchro1
The guy at the repair shop explained that the twin coils are actually the rotor. We need to dismantle the fan and use this rotor as a stator to rotate a cycloidal wing to test bench.
This cannot go very far.
