Bullet blimp.
Started by synchro1, March 02, 2021, 08:26:34 AM
synchro1
Here's a $5000. Electric  turbo fan Jet engine: Imagine the duct nacelle nested inside the circle of Washtub coils counter rotating the ring wing at 20k with the 220 AC.
This is a Hypersonic aircraft design!
Pardon,but electric jet engines in that manner would become very fast overheated (probably in future with superconctive coils)
Virtualizing the "washtube coils ring" wing system like Dyson :
https://cdn.grupoelcorteingles.es/SGFM/dctm/MEDIA02/CONTENIDOS/201505/14/00107780114810____7__640x640.jpg
synchro1
Tinman measured backspike power from a pulsed magnet in an iron Shell. Placed between the horseshoe stators, as a Hildbrand valve, the magnet core and coil would multiply the magnet strength by the Flynn factor when energized. Wraping a ferrite keeper attached between the horse shoe legs should generate 4 times the power!
synchro1
2 ring propellers on a gyro fan axle should be COP 2!
What happened with the Flynn Parallel Path Technology effect ?  2021 : https://www.qmpower.com
Which difference to the : https://www.keppemotor.com/institucional/      ?
" doubling ..... /four times " ,    but
         also " doubling ...../eight times "  up                      down " halfing ..../ one-eight ..."
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=1&ND=3&adjacent=true&locale=en_EP&FT=D&date=20121011&CC=US&NR=2012256422A1&KC=A1
[92,93,94]
Richard Fradella generator : 1000 Watt rated output,                                              nominal 1000 RPM
                                          1000 Watt        1000 RPM
halfing the RPM                     125  Watt  =1/8 rated power                                                    500 RPM
1/10 the RPM                           1 Watt = 1/1000 rated power                                               100 RPM
https://worldwide.espacenet.com/publicationDetails/description?CC=JP&NR=S57108471A&KC=A&FT=D&ND=3&date=19820706&DB=EPODOC&locale=en_EP
http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=JP&ENGINE=google&FORMAT=docdb&KIND=A&LOCALE=en_EP&NUMBER=S57108471&OPS=ops.epo.org/3.2&SRCLANG=ja&TRGLANG=en
When this embodiment configured as described above is installed in a fluid such as a sea stream, a water stream such as a river, or a wind, the rotating shaft 7 that is professionally hardened by the fluid energy rotates counterclockwise, and the rotating shaft 10 that sings professionally rotates clockwise. Then, this rotation is transmitted to the one-nion 5 via the rotating internal gear 6 and the planetary gear 8, and the shaft 3 rotates clockwise. Then, the rotation speed of the shaft 3 is obtained by multiplying the sum of the rotation speed of the propeller rotation shaft 7 and the rotation speed of the professional rotation shaft 100 by the number of teeth of the internal gear 6 and dividing by the number of teeth of −nion 5. The speed is the value obtained by adding 100 rotations of the rotation shaft covered by the pro to the value obtained, and the rotation speed is about twice as fast as that of a device equipped with one conventional propeller. Moreover, since the counter-rotating professional beaks are arranged alternately, the fluid flow does not become spiral as in the conventional case, and the energy conversion efficiency is extremely high. The rotational force is the sum of the rotational forces of each propeller, resulting in a large rotational force. The rotational energy obtained in this way can be used as various power sources by connecting a generator, a pump, a compressor, a frictional heat generator, etc. to the shaft 3 directly or further via a speed reducer or a speed reducer depending on the application. It can be used. FIG. 2 shows another embodiment of the present invention, and the same names as those in FIG. 1 are designated by the same reference numerals. In this embodiment, a rotating internal gear 6 and a planetary gear 8 led by a double shaft from a set of propeller rotating shafts 7 and 10, respectively, are arranged in a casing 1 together with a binion 5 provided on the shaft 3, and a professional rigid rotation is performed. A left-handed rotating zoro cover 11 is attached to the shaft 7, and a right-handed rotating zoro 4 to 12 are attached to the propeller rotating shaft 10.
Instead blades 2 motors,one ccw and the other cw rotation orientation ?
Generator ? By the same inventor :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=3&ND=3&adjacent=true&locale=en_EP&FT=D&date=19981222&CC=JP&NR=H10341560A&KC=A
To obtain a multipole conversion device and a conversion method by which the efficiency of more than 95% for converting a mechanical energy into an electrical energy can be realized in comparison with the efficiency of less then 50% with a conventional constitution, one apparatus can function both as a generator and a motor, a speed-up device is eliminated and the manufacturing cost can be reduced easily.
similar generator principle https://ro.linkedin.com/in/florin-eugen-tudor-frunza-63941445
GENERATOR ELECTRIC CU RELUCTANTA COMUTATA TRANSVERSAL
