Bullet blimp.
Started by synchro1, March 02, 2021, 08:26:34 AM
synchro1
This 2 meter spiral Magus windmill generates 3.8 times the lift as the original propeller :
synchro1
The conclusion is that the spiraling ring quadruples the lift of the propeller alone!  A spiral magnus wingon the coweling of this 3d printed electric jet would be interesting.
https://www.youtube.com/watch?v=yQLhwI4t6JA
Good morning,synchro1 !
Heinrich Gustav Magnus (effect)
Anton Flettner
Henri Coanda (effect)
Open
Enclosed,as chamber :
Ranque-Hilsch
Windhex
So,reinventing the ancient-classical plane propeller starter principle :
thrust generating by capsules ,by your idea instead capsules with e- jets
Perpetual "Tornado (black/white whole) in a box"
An artificial  atmospherical wet/dry,hot/cold,fast/slow  state game  like  the seasonal "tornado alley" happening
Un-/Wetter and weather : an Un-Weather generator box
www.aenertec.com talon_rms.htm    : " Put the Power of the Tornado to Work for You " !?
Reversible heat pump + wind generator(inside)  = atmospheric generator (Carnot/Biot-Savart engine)
Turbulent to laminar = compression and laminar to turbulent = expansion
Pulsative(wave-like) process
Sincere
OCWL
p.s.:
we have exposed #33/37 the Hilden-Brand and Flynn experiment results, mmf related or in mmf-emf conjunction !
In Volt/Ampere the F=BIL and counter-F relationship ?
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=2&ND=3&adjacent=true&locale=en_EP&FT=D&date=19790215&CC=DE&NR=2733719A1&KC=A1
http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=DE&ENGINE=google&FORMAT=docdb&KIND=A1&LOCALE=en_EP&NUMBER=2733719&OPS=ops.epo.org/3.2&SRCLANG=de&TRGLANG=en
[0015]
If, in a conventional generator, the field strength B, the length of its conductor is denoted by L and the current flowing through it is denoted by I, the magnitude of the opposing force F exerted on the conductor and thus on the shaft is F = BLI.
[0016]
If the field strength of the electrical device 2B is the length of its conductor L and only a current flows through it whose strength corresponds to half the current flowing in the generator, the force exerted on the armature is F '= 2B x L x 1 = LI.
[0017]
2
This shows that the force exerted on the armature of the electrical device and thus on the driving shaft is equal to the counterforce exerted on the shaft by the conventional generator.
The force is generated to act in such a direction that it compensates for the opposing force.
[0018]
Half of the generator voltage is required to allow half the current to flow through the electrical device.
Thus 1/4 of the generated power is lost to counteract the decelerating force.
The remaining 3/4 of the generated energy or a little less of it is available for external consumption.
        THE F=BIL STATEMENT :
      F with B           to        F with   1/2 B   is not a 1/2(VA)  but (1/2V x 1/2A ) = 1/4 VA
                                                   1/5 B           not   1/5(VA)   but                            1/25 VA
                                                 1/10 B           not   1/10(VA) but                          1/100 VA
                  Comparing Flynn´s mmf magnifying/diminuation and Richard Fradella generator rated RPM/Watt ratio changes
[0019]
If the field strength of the electrical device is a multiple of the field strength of the generator, for example 5 times, it is necessary that 1/5 of the generated current flows in the electrical device in order to generate the compensating force. 1/5 of the generated voltage is required for the current to flow.
Thus 1/25 or 4% of the generated energy is used in the electrical installation, while 96% or a little less of it is available for external consumption.
In this way it is not necessary that any electrical energy from an external source is introduced into the generator according to the invention for generating electrical energy.
A slightly stronger current flow provides the required torque on the shaft.
Therefore, the shaft and thus the armature are moved further and electrical energy is generated.
                                           Force and counter-force : field strength B ratio,gouverns V/A relationship
Magnet array (forced effect)
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=5&ND=3&adjacent=true&locale=en_EP&FT=D&date=20130314&CC=US&NR=2013062983A1&KC=A1
by the same inventor applied as windmill generator
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=6&ND=3&adjacent=true&locale=en_EP&FT=D&date=20111006&CC=US&NR=2011241349A1&KC=A1
and coil saving technique
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=20010710&CC=US&NR=6259347B1&KC=B1
This invention allows for the reduction in size of a high power transformers by a factor of 4 to 8 and a reduction in weight by a factor of 4 to 6, and an increase in power density by 5 to 10 in power. The efficiency of the transformer is improved by maximizing the heat transfer from the transformers interior and minimizing voltage breakdown. The thermal properties of each core 12 will dictate the quantity of the thermally conductive strip 16 material required to lower the transformer temperature to a predetermined level, some testing may be required to established the optimal amount needed to provide proper cooling.
and motor or generator size/weight ? 8)
These and other objectives are obtained by placing thermal conductive strips between the turn layers along the axis and perpendicular to the turns of an high power electrical device, such as a transformer or motor, which extends outside of the windings or between the laminates of the core. The excess heat is conducted outward from the interior of the device along the strips to the outside of the device's windings where it is extracted from the protrusions by means of a highly thermal-conductive potting compound that has a short thermal path to a small heat sink.
in future lower costs production
not rare magnets material : Iron nitride
https://nironmagnetics.com/
But  ::)  : for demanded flexible load (device electrical) output we see now that there is a controle system in need ,
               flexible V/A force/counterforce operator
An EPROM with FUZZY LOGIC-App inside for such an (il :o -)logical (seeming 8) ) complex/ity like here : https://patents.google.com/patent/WO2014167269A1/en
quantum mechanics work controle ,Nature is a littl´ KOMPLEXITIV,RELATIVISTISCHE KINEMATIK (Uni theme)
https://translate.google.com/translate?sl=de&tl=en&u=https://www.abiweb.de/physik-relativitaetstheorie/relativistische-kinematik.html
https://translate.google.com/translate?sl=de&tl=en&u=https://itp.tugraz.at/LV/schnizer/Analytische_Mechanik/node11.html
awarded wind force conversion method :
https://www.jugend-forscht.de/stiftung-jugend-forscht-e-v/historie/geschichten/europas-jugend-forscht-fuer-die-umwelt-yeer.html
1995Ákos Honti, Szilárd Pataki, Ungarn
Ein neuer Typ von Windmaschine
similar construction : https://patentauction.com/patent.php?nb=2261
https://brisam9.blogspot.com/2013/12/us-patentwindmill-1000-time-more.html
:o  https://programs.dsireusa.org/system/program/detail/734      -tax credit per KWh  ?
A wind farm made from this blinking sail windmill which cost $100 million it will generate electricity more than a wind farm
cost $10 billion made from present windmills.
smaller wind farms ratio :
10    million    instead     1 billion   investment
1    million     instead 100 million  investment
100 thousand  instead 10 million   investment
With which electric generator costs per KW he calculates  ?
we can read here
As we see the crane price can be as low as  $22,000 where the four frames will cost less than $15,000
So with less than $40,000 we will have a 1MW windmill, if we add the generator price and the foundation cost the entire blinking sail windmill cost will be less than $175,000. With such price the blinking sail windmill will land slide the world of wind power generation.
$175,000 total costs- $40,000 windmill  = $135,000 (less foundation costs) for a 1 MW electric generator !?
$175,000 / 1 MW =          $175/KW
1$cent/KWh electricity generation range [ less (political/ecological) tax credit = Zero costs]
investment high per KW  comparison
https://judbarovski.livejournal.com/tag/wind%20turbine
I estimate a cost of a construction of the wind turbine for the case of 3,000 kW to be much less then a hundred US dollars per kW, including a cost of a tower.
land lease/rent/buy costs per KWh ?
When f.e. in Germany from 25€cent electricity price only 8 Eurocent are power plant related,a diminuation from the generation price would only have a price decrease effect from 25 to 25(-7 or 8) = 17/18 €cents per KWh consume for net-grid endconsumer
Alternatively,off-grid or hybrid net-on/off :
A portable 3000 RPM Mukherjee generator,2021 construction standarts,1 KW steady DC output : 500 US$/KW
Electricity generation costs by 24/365 production : 1 $cent/KWh (less incentives/tax credit ?)
+Battery/capacitor-set for Wattpeak ≥ rated KW demand and/or storage
Home power plant electricity generation - off grid - in the 5 €cent/KWh average (~ US b2b e-price)
1 KW x 8766 h = 8766 KWh per year is much
But
1 KW as "kitchen power demand + inrush current peak" is low ,up to 15 KW peak demand not unusual
A water heater 1500 W,but only 1/15 per heat process = 100 Wh
A toaster,coffee machine,microwave owen ,electric owen plates with 1500/3000 W rated consume ,hair dryer ,.....
Clothes dryer with motor : rated 1500 W motor ? IC phase/inertia 7500 Wp demand
Washing machine ,rated motor .....
And better : not in seriell use put all in the same "time demand" : 5000+ Wp accumulation x inrush phase
+ Electric room heating/cooling !?
Thinking BIG and THINKING SMALL
synchro1
This rolling fabric Magnus wing increases lift by 27%.
