Motor search for lenz less or lenz assisted.
Started by MagnaProp, May 03, 2021, 12:24:02 AM
synchro1
This magnetic reed switch has a polarized iron rod  that was magnetized by contact with the neo sphere. It is attracted by one pole of the sphere and repelled by the other. The sphere is receiving two power pulses from the coil in Adam's resonance. One from the backspike.
Collected BEMF from a recovery diode and an output coil turn this simple design into an Overunity generator.
Spring "Reed Switch" - YouTube
synchro1
The magnetic reed switch is a self runner in Adam's resonance. You can witness the neo sphere spontaneously self regulate a resonant dwell in the video.
The resonant frequency RPM is controlled by the coil resistance and discharge rate. A high perm core and backing magnet coupled with a Mosfet would improve the COP.
The Lenz reverse power pulse coupled with the recovery diode output together are overunity.
synchro1
The iron pin is simply a braid nail. 2 different gauge wires allow sufficient rigidity to slow the speed down to Adam's resonance. The clumsy overbuilt switch supplies the correct delay.
kolbacict
synchro1
Quote from: kolbacict on October 28, 2021, 01:53:15 PM
Is this your video?
Yes. The electromagnet is a pot core. The biasing neo cube only effects one pole of the EM. This leaves the center pole weak. The oscillation occurs when the magnet stack is positioned in the neutral zone between them. Just a razor width.
The video appears to show a casual positioning of the neos on razor blade, but it was after many tries and within a millimeter of the neutral zone. I knew exactly where to place it. You need to fish for it!
The other alternative explanation, because you stated that you couldn't replicate the effect, is a virtual short caused by crossed wires. Either way the oscillation consumes power.
