Motor search for lenz less or lenz assisted.
Started by MagnaProp, May 03, 2021, 12:24:02 AM
kolbacict
Did you think that when a steel plate vibrates near a magnet, the magnetic permeability of this plate also changes? ;)
synchro1
Quote from: kolbacict on October 30, 2021, 03:51:33 AM
Wesley Gary patented an oscillator with magnetic saturation
as an operating principle.
synchro1
The degree of offset was calculated by Newman and determined to be 17 degrees off TDC. This offset delivers an equal force to the rotor to balance the weaker Lenz Propulsion force at TDC. Free power is amplified by the pole adjacency to the coil during the collapse event!
synchro1
Here's a sketch of the angle :You can superimpose this over the Crop Circle angle above.
synchro1
This motor generator has an SRF. A sonic transducer can couple with the self resonanting frequency.
Coupled with the work of Keely. Broadcasting a sound wave toward the neo sphere at Adam's resonance SRF should help power the spinner.
The multi coil version below would run at a higher RPM in Adam's resonance because the discharge rate of the smaller coils is lower. The Dwell would remain the same.
