Motor search for lenz less or lenz assisted.
Started by MagnaProp, May 03, 2021, 12:24:02 AM
synchro1
The Sphere magnets would need to be arranged NS in pairs like the wheel magnets pictured below to run in Adam's resonance.
synchro1
The Coil Ohms and discharge time determine not only the NS magnet seperation but also the number of pairs on the rotor and the diameter of the rotor.
The position of the (Reed Switch Trigger Magnets) in the schematic show the inventors TDC in the middle when ideally it should be where the Crop Circle shows it. The idea is correct and open to fine tuning! The Backspike needs to pulse the trailing magnet at top dead center! Doubling the magnets then seperating them that much does nothing to help.
A lower grade magnet of equal weight could balance the primary pulse.
kolbacict
QuoteWesley Gary patented an oscillator with magnetic saturation
as an operating principle.
But in order to move the magnetic shield and cancel the field, mechanical work must be done.
The energy for this will eat up all the useful power output.
Quoteas an operating principle.
As a principle, yes, but it won't work.
synchro1
Quote from: kolbacict on November 01, 2021, 01:57:19 AM
The energy for this will eat up all the useful power output.As a principle, yes, but it won't work.
synchro1
"The nail drops off when the iron shield demanetizess in the neutral zone"
The question is does the razor blade demagnetize in Neutral Zone?
