Motor search for lenz less or lenz assisted.
Started by MagnaProp, May 03, 2021, 12:24:02 AM
synchro1
The placement of the rotor magnet at (Backspike TDC) amplifies the recovery current. The inventor of the schematic imagines adding advantage by pulsing between the NS magnets. Repositioning the trigger magnets at Adam's dwell would multiply his recovery power. His approach of double the magnets at twice the distance is pretty stupid!
kolbacict
Does it really work ?!
And without batteries and gasoline?
synchro1
We have to keep in mind that Gary's oscillator works at a "Bar Bird" rate! The untested idea looks like a good idea! De saturation compared to chemical evaporation.
The iron shield attracts down,  raises the adjacent magnets, then the shield reaches saturation and withdraws with less force.
synchro1
Lidmotor is pointing to a phantom S pole on his monopole rotor. This is a Reed switch diode looped pulse motor. Lidmotor generates power with an Adam's back kick and recycles the BEMF. This is a self runner!
synchro1
A close look shows the Reed switch off to the side. A normal magnetic switch would trigger at the strong pole but not the Panthom pole. The phantom pole would still power the rotor from the kick back!
