Reactive Current - Parallel RCL
Started by nix85, June 01, 2021, 08:43:14 AM
nix85
Lanca kilometer links AGAIN, you gotta stop doing that. Understand most of us zoom in cause site font is too little, with your kilometer links it makes any thread impossible to read.
From late Jerry Decker
Years ago, at one of our Vanguard Sciences Roundtables in Dallas, a man who was President of a Gravity Research organization swore to me that he received a call from a stranger telling him he had developed a means to reduce local gravity to control the weight of any mass to which it was attached.
The man telling me this didn't believe it so the caller offered to demonstrate the device but he wouldn't permit any photos or give any details of how it worked. My friend drove out to the far end of a mall in Waco, Texas where the caller was sitting inside a Jeep. No one was else was around so they had no fear of being interrupted.
They greeted each other and the caller got inside the Jeep, put it in neutral and asked that my friend get behind the Jeep and push it to get an idea of how hard it was to move. The caller sat inside the Jeep while my friend pushed it about 5 feet. The caller put on the brakes, turned on the engine and backed it up to the original location.
My friend walked to the drivers side where the caller had turned off the engine. He reached under the dash and flipped a hidden toggle switch. The caller sat in the Jeep and asked my friend to again go to the rear of the Jeep and push. This time, the Jeep moved with the touch of a finger! Like a giant balloon offering almost no resistance as it travelled a good 10 feet with the slightest push.
Of course, he was astonished and wanted to know more. The caller got out of the Jeep, went to the front and crouched down, pointed to a small black box mounted inside the wheel well above the tire. A cable ran from the small black box to a device inside the Jeep which the switch controlled.
Each wheel had an identical device and cable leading to the inside control device. The caller said when power was applied, the local gravity was repelled so that the Jeep was enveloped in an energy field where gravity and inertia were reduced, that he had it set for a given percentage of weight loss but could adjust it to whatever level he wished, even to outright levitation.
The caller would not provide any details about the nature of the box, but my friend thanked him for the demonstration, turned off the gravity nullifier device and drove off into the sunset leaving my friend baffled at what he had just seen.
As is so often the case with such stories, I asked my friend if he got a name and contact information for this mystery inventor and he said yes, but his wife washed his clothes where he had left the paper so it was destroyed.
I asked him if he noticed anything unusual and he said he thought there was a slight whirring sound when the device was energized which led us to think it could be a unidirectional, inertial technique to redirect a spinning weight in an upward direction.
https://keelynet.wordpress.com/2009/03/07/a-tale-of-negative-gravity/
Because me interests the experimental field and results research,nix 85 !
gravitational field (partial) neutralization and gravitational field artificial (re-)engineering in (orbital) space
http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=DE&ENGINE=google&FORMAT=docdb&KIND=A1&LOCALE=en_EP&NUMBER=19539390&OPS=ops.epo.org/3.2&SRCLANG=de&TRGLANG=en
Sincere
OCWL
nix85
Don't act like a jerk, you are giving everyone a hard time.
Just shorten the links.
 Fantasies are typically associated with scenarios that are statistically implausible or impossible in reality .
from impossible or only implausible ( for outsider,theorists) to : plausible by physical prototype demonstration
                                        q.e.d. =   demonstration style and confirmation
                     " Masterpiece " , a honory peer-approved and granted "Doctor/-a work Titular-PATENT (leased)"
                       and/or economical " approved and granted peer- "(technical standart)PATENT"
           ( but often inventors only apply without approvement interests ! financial budget,altruism,results in use preview, et cet. )
from experience (!?) to re-/search to repeat action-/reaction experiments (unidirectional/reversible ?)
this is basic research (lab,field) and later "scientifical knowledge",in hope conventional application
                                                         natural/artificial
                        a knife a soldier use as eat instrument or as bajonett-application
