Reactive Current - Parallel RCL
Started by nix85, June 01, 2021, 08:43:14 AM
nix85
Some more quotes first one along the more primitive kind of flight
Sage Agastya is mentioned in Mahabharata of 4000 BC. The "Agastya Samhita", ancient document on gems, gives Agastya's descriptions of two types of aeroplanes. The first is a "chchatra" (umbrella or balloon) to be filled with hydrogen. The process of extracting hydrogen from water is described in elaborate detail and the use of electricity in achieving this is clearly stated. This was stated to be a primitive type of plane, useful only for escaping from a fort when the enemy had set fire to the jungle all around. Hence the name "Agniyana". The second type of aircraft mentioned is somewhat on the lines of the parachute. It could be opened and shut by operating chords. This aircraft has been described as "vimanadvigunam" i.e. of a lower order than the regular aeroplane.
And scientific analysis of above mentioned Samarangana Sutradhara, 11th century text attributed to King Bhoja. I personally don't like this one too much because it implies mercury is used as jet propulsion. This probably was so in case of these vimanas, but mercury is usually used for gravitational effects. It seems the newer the reference more primitive the technology.
"There are two types of Vimanas described in Samarangana Sutradhara of Bhojadeva. They are Laghu Dharu vimana and Alaghu Dharu vimana. Bhoja deva in his text has also mentioned that he personally has seen a few of the vimanas which he has described."
Laghu Dharu Vimana
Verses 95-96 of chapter 31 of Samarangana Sutradhara describes Laghu Dharu vimana. It is the most fascinating yantra described by Bhojadeva in his works. Even though he gives the barest details, this book is one of the few sanskrit texts which speaks about the actual construction of vimanas. (Sharma 2012:380-81)
"Laghu dharumayam mahavihangam dhruda suslishta tanum vidhaaya tasya|
Udare rasayantram aadadeetha jvalanaadhaaramadho asya chaati poornam||
Taroodaha purushastasya pakshadwandwochaallaprojjitena anilena|
Sputasvantaha Paaradasyasya shaktya chitram kurvannambare yaati dooram||"
According to Bhojadeva main material of the body of vimana is lightwood-,,Laghu Dharu‟, shape of the vimana is that of a huge bird-,,maha vihanga‟ with a wing on both the sides. He explains that the internal structure has a fire chamber with mercury placed over flame which acts as a motive force. The power generated by the heated mercury, helped by the concurrent action of the wings which are flapped by a rider inside, makes the yantra go up and travel far. (Raghavan 1952:23-24)
Alaghu Dharu Vimana
Verses 97-98 of chapter 31 of Samarangana Sutradhara describes Alaghu Dharu vimana which is a heavier Dharu vimana. (Sharma 2012:381-82)
"Ityameva suramandiratulyam sanchalatyam alaghu dharuvimanam|
Aadadheetha vidhinaa chaturo antastasya paradabruthan drudhakumbhaam||
Ataha kapaala ahita manda vahni pratapta tat kumbha bhuvaa gunena|
Vyomno jhagityabharanatvameti santapta garjad rasarajashaktya||"
While laghu Dharu vimana is in the shape of bird, alaghu Dharu vimana is in the shape of temple. It flies along a heavy aerial car made of wood. It is a heavier Dharu vimana which contains four pitchers of mercury over iron ovens. When mercury i.e. ,,rasaraja‟ is heated, it explodes quickly and becomes an object of decoration in the sky mainly because of pots heated by the slow ignition burnt within the steel or Iron potsherds. Indologist ,,William Clendenon‟ has described Mercury Vortex Engine in his translation of Smarangana Sutradhara as follows.
"Inside the circular air frame, place the mercury engine with its electric/ultrasonic mercury boiler at the bottom center. By means of the power latent in the mercury which sets the driving whirlwind in motion a man sitting inside may travel a great distance in the sky in a most marvelous manner. Four strong mercury containers must be built into the interior structure. When these have been heated by controlled fire from iron containers, the vimana develops thunder-power through the mercury. And at once it becomes like a pearl in the sky." (Childress 1991:256)
According to Bhojadeva the boiling mercury ovens produce a terrific noise which can scare away the elephants. Hence it is used in battles for the same purpose. The roar could be increased by strengthening the mercury chambers, so that elephants are thrown completely out of control. This specific military use of aircraft against elephants tempts one to suggest that the Hasti-yantra advocated by Kautilya against elephants was something like the heavier Dharu-vimana described by Bhoja. (Raghavan 1952:24)
https://www.iosrjournals.org/iosr-jhss/papers/Vol20-issue12/Version-5/D0201251620.pdf
All in all, there is no doubt flight is not a privilege of modern times, in fact, public flight technology of today is far more primitive than it was in times bygone.
nix85
For more fascinating references to ancient aviation read chapter 4
https://ug1lib.org/book/5235463/72c6e8?id=5235463&secret=72c6e8
Also this doc, youtube will not show it even if you enter the title with exact quotes,
you gotta scroll way down.
https://www.youtube.com/watch?v=GbWMw249xY8
nix85
In attachment interesting book 64 Secrets Still Ahead of Us By Jonathan Gray with legend from Bolivia i been looking for for a long time and couldn't find it again till now.
Content of the whole book:
Cartography
1. Maps more accurate than ours
2. Complex 3-dimensional map made with unknown
technology
Astronomy
3. Knowledge of planet beyond Pluto
4. Calendars more accurate than ours
Metallurgy
5. Bronze harder than we can make
6. Iron that will not corrode
Everyday items
7. Enormous castings of pure iron (we can't)
8. Alloy processes not yet discovered
9. Copper hardened by an undiscovered process
10. Silver that does not tarnish
11. Gold plating technique superior to ours
Construction size and techniques
12. Architecture beyond our scope today
13. Lifting capabilities beyond ours
- engineering feats never equalled since
14. Larger than our biggest modern buildings
15. Surface smoothing and fitting accuracy superior to ours
16. More accurate standard of measurement
17. Construction speed superior to ours
18. Buildings which are virtually indestructible
19. Shaking towers – a secret unknown
20. Cement superior to modern Portland cement
21. A process for softening hard rock
22. Non-circular, 5-point-star shaped holes drilled
23. Drills faster than modern power drills
24. Ability to slice through hardest materials without
friction or heat
25. Interlocking tunnels thousands of miles in length under
land and sea
26. Canals and dams larger than ours
27. Construction methods beyond our present capability
Town planning
28. Town planning for centuries ahead – nowhere done
today
Mechanical – electronic
29. Robot , long buried, able to shriek and flap its
wings
Everyday items
30....Books composed of gold leaves
Clothing, textiles
31. Cotton grown in various colours
32. Textiles finer than is possible in a modern loom
Art, sculpture
33. Three dimensional effect by luminous paints
34. Finest stone engraving in the world
35. Mysteriously high carvings
36. Art visible only in a photograph (also visible/invisible
art)
37. Neon bright "movie" in granite
38. Crystal skull beyond our ability to produce
Health, medical
39. Currently incurable diseases cured with medicines
today unknown
40. Obsidian instruments 1,000 times sharper than today's
conventional surgical blades
41. Skull operations technically superior to our own
Electricity
42. Perpetual lamp able to burn for 2,000 years
43. More known about matter, light, and ether properties
than we know
44. Inexplicable paired TV screen transmission
45. Book TV with vanishing pictures
Surveying
46. Cross-country lines laid out straighter than by the best
of modern survey techniques
Flight
47. Aircraft able to fly straight up, down, forwards, or
backwards
48. Manouvers that helicopters can perform today only
partially
49. Ability to hear conversations in enemy planes
50. Flight powered by mercury
51. Specified tricks in flight to deceive an enemy (and
formulas that would revolutionise modern aviation)
52. Flight powered by sound waves
53. Electromagnetic energy from the atmosphere
54. Vehicles adapted to travel both in the sky as well as on
or under the sea
Intriguing secrets
55. A container which weighs the same whether full or
empty
56. Fire which burns in water
57. Singing statues
58. Large public baths heated by the flame of a single
candle
59. Objects suspended indefinitely in mid air
60. Alchemy (transmuting one metal into a different metal)
61. Invisibility apparatus
62. Visible then invisible, bridge
63. Time viewing devices
64. Brain transplants
nix85
And what about human levitation, in case you did not see this African shaman filmed by German TV crew in 1989, 0% possibility of fakery.
https://www.youtube.com/watch?v=tW6pVFOpE6Q
nix85
@Lanca Yea i know the story of Tibetan sound levitation.
Also these Russians, but are these real stones or. Hm.
https://www.youtube.com/watch?v=LILH5L9ys5c
