Reactive Current - Parallel RCL
Started by nix85, June 01, 2021, 08:43:14 AM
nix85
For energy transfer to happen voltage and current must be in phase.
Reactive power means voltage and current are not in phase, energy bounces back n forth.
Resistance brings them in phase.
Exception is an antenna, voltage and current are 90° outta phase, yet it radiates.
They have radiation resistance.
https://www.youtube.com/watch?v=OuVQqFhualI
https://de.wikipedia.org/wiki/Thomsonsche_Schwingungsgleichung
https://translate.google.com/translate?sl=auto&tl=en&u=https://de.wikipedia.org/wiki/Thomsonsche_Schwingungsgleichung
oscillating circuit
E : magnetic field energy of the coil
E : electrical field energy of the capacitor:
Total energy of the system (constant)
how a circuit " becomes harvester/generator/converter" ?!    "imaginary/real" magnetic field "particles" and electric field "particles"
        magneton
https://translate.google.com/translate?sl=auto&tl=en&u=https://www.chemie-schule.de/KnowHow/Bohrsches_Magneton
        graviton ?
        https://en.wikipedia.org/wiki/Graviton
Thomson or Kelvin
https://de.wikipedia.org/wiki/William_Thomson,_1._Baron_Kelvin
https://translate.google.com/translate?sl=auto&tl=en&u=https://de.wikipedia.org/wiki/William_Thomson,_1._Baron_Kelvin
condensator/capacitor and spring analogon related         maximal temperature and minimum temperature : 0°K(elvin)
bedingt das e-Feld das b-Feld,oder inverse  oder ist es nur "gedankliche Annaehrung" ? 1/2/3/4D ?
does the e-field cause the b-field, or inverse, or is it just ,the e-/b-field images,static "mental approximation"? 1/2/3 / 4D?
e-field : + to - orientation
b-field : cw/ccw spin (arrow) orientation
the two in one
https://upload.wikimedia.org/wikipedia/commons/thumb/1/16/Lorentzkraft_und_Induktion.svg/220px-Lorentzkraft_und_Induktion.svg.png
https://translate.google.com/translate?sl=auto&tl=en&u=https://de.wikipedia.org/wiki/Lorentzkraft
                                                            or Biot-Savart also Ampere also Laplace Force
natural particles  behavior or enforced being -in tube/in coil - "enclosed" and deficient in freedom degrees or (brownian/temperature) movement speed increasing cause (sub-)ion(-particle)-"wind shadow" effect (spin positive/negative ,neutral)
different particles and their polarisation (and MeV) lifetime !
air core versus solid core : movement ! ( Ether -GEDANKENPROBLEM : wave/light !  ::)  )
Resistance brings them in phase.  in Ohm,in Mho (or Siemens ),by RESISTANCE ZERO ?
  A/m finitum number ?
https://phys.org/news/2012-03-efficiency.html  "voltage decrease" is the boss here
Plancksche or Diracsche Konstante ! https://translate.google.com/translate?sl=auto&tl=en&u=https://www.chemie.de/lexikon/Plancksches_Wirkungsquantum.html
is the boss its number here : https://overunity.com/18878/reactive-current-parallel-rcl/dlattach/attach/181834/image//
They have radiation resistance. :o
"They" ? the device/s ? the "emissive/receiving" medium particles ?  L.A.S.E.R,M.A.S.E.R   : .... E.R.   ( P.H.A.S.E.R.)
" resistance " : electrical,magnetical,kinetical-mechanical ?
a bullit shoots out the pistol/gun chamber/channel  : in chamber phase velocity,outer chamber :
in air/solid medium ( bullit straight/rotative movement ?) ballistics
carbon : conductor or isolator ?
nano-carbon : conductor or isolator
carbon or nano-carbon on/off switch ? METAmaterial
Nano tubes internal a-/normal movement behaviour ? attraction/cohaesion (e/-, m/-) forces ?
decreasing Voltage and high A/m :
  http://www.rexresearch.com/kemeny/kemeny.html
A new electric circuit system for electric cars
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=2&ND=3&adjacent=true&locale=en_EP&FT=D&date=20190328&CC=DE&NR=112017003611A5&KC=A5
Device for an electric drive for electric vehicles
                                                reactive-displacement current-circuits
nix85
https://en.wikipedia.org/wiki/Radiation_resistance
Unlike other resistances found in electrical circuits, radiation resistance is not due to the opposition (resistivity) of the material of the antenna conductors to electric current; it is a virtual resistance due to the antenna's loss of energy as radio waves.[2][1]
to radio conversion (resistance) losts
give me please an (near) 100% conversion principle !
Betz/Carnot cycle efficiency ( also valid for e.-m.-circuits ) : over this given efficiencies !
You can get high C.O.P. devices,but the efficiency factor <(theoretical limit same) =1  :
https://translate.google.com/translate?sl=auto&tl=en&u=https://de.wikipedia.org/wiki/Carnot-Wirkungsgrad
        eta
But 8)  : f.e. https://worldwide.espacenet.com/publicationDetails/description?CC=DE&NR=102010044865A1&KC=A1&FT=D&ND=3&date=20120315&DB=EPODOC&locale=en_EP
in using "forbidden "( non Physics ,algebra and geometry) "pure statistical/abstract " maths lessons formula its laws and order :
Bruch/Division : Divident and Divisor = Quotient  Divisor = positive number or negative number ,NEVER ZERO
                                                   simple calculator gives : SYNTAX ERROR ( forbidden ! Denied !)
                      When a number is negative than there has to be a cross point from negative to positve ,in time - ,in local distance)
in PHYSICS ZERO is the MIDDLE POINT from the XYZ Coordination-Cross,with movement from/to/cross ZERO
                                         Multi-dimensional  PHYSICS SYNTAX in formulas applying !
                                       We read even about "negative time " in Quantum-mechanics  !
                                                reactive and active current compact circuit,off-grid,self-charging
nix85
Like i said before, EVERYTHING RADIATES in almost all circumstances.
