Would like to Submit a PDF with regards to a Gravity Assisted Device
Started by GravityAntiGravity, June 28, 2021, 07:49:50 PM
Do any members want to receive research data on GAGA Engine
Do any members want to receive research data on GAGA engine
1 (50%)
Do any members request build info
1 (50%)
Total Members Voted: 2
lota
Hello
I think I will mount the ramp on tooth frames. Or a double ramp on linear bearings. The profit can be increased by reducing friction.
Greeting
Lota
kajunbee
In your baseline test did you lift the weight with the turntable shut off. Or was the weight disconnected entirely. The bodine motor turning the generator with weight disconnected should be your baseline I would think.
GravityAntiGravity
Smoky2 has wrapped his mind around the principles. There is enough information with pictures and white papers that equations can be formulated to prove the math.
GravityAntiGravity
For the question how was the baseline derived.  There is clutch assembly that engages the GAGA 3 engine with the bodine motor and generator.  The baseline was conducted with the clutch assembly disengaged.  Baselines were also completed with the drive shaft completely disconnected.
lota
Hello
how much and how big are the magnets. Could it also be built horizontally with springs?
Greeting
Lota
