Andrea Rossi Plasma Reactor
Started by hermesatar, December 09, 2021, 01:19:40 AM
hartiberlin
hartiberlin
Well, another typical Rossi demonstration, according to the motto: As you can see, you don't see anything ... ohhmann .. Well, really badly presented ... to buckle what he's doing, you have to look at it at least 3 times .. Here under the video in the description you can find some PDF files. where an attempt is made to explain something ... https://www.youtube.com/watch?v=r4_NyyIZq70&t=774s So I'll try to describe it ... Rossi probably has a cube-shaped box, about 10x10x10 cm,
where he claims that it would produce 100 watts constantly ... To operate the whole thing, he would only need about 1 watt ... Then it also has control electronics, which, together with the lamp, consume approx. 1 to 4.5 watts. On his experiment table you can only see a few not so bright LEDs in a reflection of the plexiglass plate, maybe from a headband LED lamp ...
but that is probably not the right LED lamp yet ... You can see this as a radiator in the end compared to a 98 watt? LED lamp ..
Hmm ... 98 watts seems strange to me, there are no such lamps, maybe he meant a 100 watt normal incandescent lamp ... hmm ... So his LED lamp should only consume about 4 watts, okay, the brightness was okay for 4 watts, but also not that extremely bright ...
They had talked about 10,000 lumens beforehand, it was definitely not that bright I would once to say.... For me it looked more like a 10 to 30 watt LED spotlight ... So it was definitely not brighter ... So I looked again, they had probably used a 98 (100) watt LED spotlight as a comparison, but the room was also illuminated much brighter,
even outside the spot area ... Well, they said, however, that they first need 1 million pre-orders before they want to have it produced ...
I think it won't work like that again .... 🤦🏻‍♂️🤦🏻‍♂️🤦🏻‍♂️🙈
hartiberlin
What do you think about the presentation ?
Is it for real ??
Many thanks.
AlienGrey
Hi; Stefan, I watched the video but it's almost impossible for me to say one way or the other.
It's a bit like the early micro CPU day's he needs to produce a project or device and publish it
for tech minded people to pace test it's capabilities time for monkeying around is to short
we need results on a global scale,
After looking on the Net for E--Cal (cold fusion) I found this same guy with less hair so
what you see isn't what you get, perhaps or perhaps not.
https://skepticalinquirer.org/2019/01/why-e-cat-is-a-hoax/
