RESSURECTED TINMAN NEW INVENTION.
Started by seychelles, December 18, 2021, 10:54:04 AM
synchro1
Two high perm ferrite core coils like this with powerful backing magnets in opposition positioned to attract the monopole stator.
synchro1
Look at the field distortion as shown in the sketch below:  The attraction field power is definitely magnified between and outside the opposite poles. The field balloons.
Very importantly, magnets will not saturate like the metal stator. This supplies a considerable Torque advantage to this kind of attraction motor. A recovery circuit would return 100% of the input power. That would leave the powerful attraction tourque as overunity output.
synchro1
Compressing opposite magnetic fields balloons them. The magnification works the same way with the rotor monopole as it does for the stator sandwich. Both the compressed rotor monopole and the stator fields are enlarged and amplied by the bucking fields. This involves the appearance of a second phantom magnet in the rotor. Double the advantage!
It's interesting that the Adam's Motor focused four N poles on the power pulse: 2 from the rotor and the 2 from the opposing side stator coils. It could run off a simple contact if the neutralization coils were in series and parallel. One Mosfet could run a radial flux GAP magnet attraction neutralization motor with 12 coils and 6 monopole rotor magnets.
Spring scale attraction force test results on a siamese monopole and bucking field stator magnets would be welcomed.
synchro1
Attaching a Torque arm to a spring and drive shaft could spin a heavy flywheel with a ratchet release action in the zone of maximum attraction with a simple solinoid crank mechanism. This design can scale up to a Radial to compete with the axial flux concept.
Hello synchro1,fine experiments offering :
to #126 the theoretical assumption in image kind we can use in real ferrit powder which gives us a physical visual magnets circuit orientation and distance approach
like to see here : https://web.archive.org/web/20160227140906/http://geminielectricmotor.com/
                            https://web.archive.org/web/20160227141156if_/http://geminielectricmotor.com/Image2.gif
similar : flux detector
https://www.magnet-shop.com/office-education/school-education/flux-big-sheet-magnetic-field-viewer-150-x-150-mm
beside the often forgotten LNaudin demonstration : http://jnaudin.free.fr/html/2magpup.htm
                                         axial repulsive force            versus          tangential repulsive force
to # 127 : what are/what is a            " siamese monopole "  ?  Never heared !   (~ mirror monopole ?)
Thanks for the public view !
Sincerely
by save and successfull weekend wishing
OCWL
