Thanks to ALL for your help!!
RESSURECTED TINMAN NEW INVENTION.
Started by seychelles, December 18, 2021, 10:54:04 AM
synchro1
Take a look at this Magnet Beam amplifier :
synchro1
The Magnet Beam has 4 axial cubes compressed by pipes all with N pole pointed in and a 5th on the perpendicular N pole in. The 5th coil could be replaced by a GAP coil that current reversed. Imagine the attraction field strength of 2 beams of 5 magnets in opposition to a mirror monopole rotor magnet. Like compression from 2 Halbach arrays.
Shielding the 5th coil neutralizes the magnet beam entirely. Projecting the magnet bubble requires the GAP coil to polarize in sympathy with the N pole. The shield field drops to zero.
truesearch
I'm having some trouble understanding for-sure what the "pipes" are that appear on the ends of the magnets?
Do you have a clearer diagram of how to build this "Magnet Beam" configuration?
And this part gets my interest
QuoteShielding the 5th coil neutralizes the magnet beam entirely.
How do you "shield" it for sure?
synchro1
4 axial magnets same pole faceing in on the 4 spokes of a cross. The 5th magnet of equal strength is positioned like an axle to the cross hub. This pushes the 4 magnet cross field to the side. Everything else you see is the frame needed to press the magnets together forcibly. The side beam dissapers when the perpendicular magnet is removed. An H bridge would need to amplify and Neutralize a GAP coil to power and mask the beam. The dividends come from masking 5 magnets for the cost of masking one!
Imagine the power of the attraction field between 2 magnet beams faceing each other in close opposition.
