Build 2
Started by Johnsmith, December 22, 2021, 08:33:09 PM
Johnsmith
  The pictures are of the hub core for my next build. I still need to add 1/4 x 1 1/2 inch slots on all 8 sides. I might wait until
next weekend to rout them or by a tool for my drill press and it might go more quickly. This will allow for all 8 arms to be
equally spaced and positioned. Also this hub core was the last thing I worked on today. I have some minor detailing to do
for the parts that I cut for my current build.
Surprisingly enough, it does take some time to drill, glue and cut wood. This is because everything has to be set up and
adjusted. And with what I need to do or want to do so I can get the parts I cut ready to mount, I'll do that as the week go by.
I'll also post some pictures which will show the stages of manufacturing that parts go through. This will help everyone to
understand why it takes time to build something. Even with THX4 he isn't showing how he writes his programs or designs his
parts which I am sure can require a lot of time and work.
And by letting everyone know about the manufacturing process, if anyone wants to build a Bessler type wheel of their own,
this will help them. An example is when cutting the kickers, I went with the 31.5º angle which can be locked into on my miter
saw. I wanted 30º but a preset lock position is simpler. And then I found that if I used a spacer when fastening blanks to a
piece of wood, a stop can be used so all cuts will be the same., on each cut of the kickers, I just rotated the saw so I could
cut both angles before switching the blanks I was cutting. Before I realized that I was removing one piece and then fastening
another piece to make one cut. Basically I reduced the amount of work that I did. And if things work out with my current build,
people will know of one source to get some build tips from.
With the hub core for my next build, I quit trying to measure it because everything was being cut at a 45º angle. So instead,
after making 2 cuts I would measure their faces. I did walk around all 8 sides so material would be removed evenly and any
adjustment that I made to the fence would be the same for all 8 sides. This is where if cutting 2 or 3 faces then you adjust the
fence, if you have the wrong face against the fence then you might've just ruined all of your work and will have to start over
again. Why cutting all 8 sides before making an adjustment can save you from making a serious mistake.
And with the shop vac (shop vacuum), it didn't seem to suck up much saw dust. But if you look at the picture of the run off table,
it's shelf is clean. Previously it would have a lot of saw dust on it. What the shop vac did was to create a dead air space under the
table saw. This kept about all of the saw dust in one place which makes cleanup so much easier.
p.s., if you look closely, you'll see a metal part inside the hub core. I'll be using a 1/4 inch diameter bolt or screw to lock the axle
into place. Because this will push those parts into the wood, when I used a step countersink it created a soft area for that part to
go into. Still, when it's called trial and error or research and development,  that's when people learn for themselves what works for them.
Johnsmith
 There is a YouTube channel called Alizee DeFan. I think it was actually Alizee who did the channel.
We did exchange a few messages and context can be telling. ie., how or what a person says. I think
it was her way of promoting women in music.
https://www.youtube.com/watch?v=xq-aTe77bkA
Alizee DeFan; https://www.youtube.com/watch?v=QBAiheqyB8Q
Donc le C(h)ampus der Elysien [ Helden-/Mars(ianer)/Zermarterte-Feld/Fuersten-Feld )] I would not das Kindche von der Bettkante wegstossen !
https://www.youtube.com/watch?v=pvh-ieuM8yg
Vom Fluszbett der Zeit ,natuerli ! 8) ;D J`aime "freche Fruechtchen",avec creme fraiche !
La Isla Lolita.  Aonde ? Lesbos ?
O tempi ,o Mori : https://www.google.com/search?client=firefox-b-d&q=alizee+2022
                              Forward to the Past ( like the #126 1rd vid  100% PLAYBACK show )
La Isla (now) Lola,. (comparation Alizee Jacotey , 2000-2021 vids )  PT shout : " Bola !"  ::) ;D
https://www.youtube.com/watch?v=arZZw8NyPq8
    Watt se nur an der Kersche ham`? :P
                                     https://www.obstbau-steegmaier.de/wp-content/uploads/2016/11/Produkte_Kirschen_Kirschen-969x591.jpg
Salut
OCWL
Johnsmith
Quote from: lancaIV on March 14, 2022, 05:48:29 AM
Salut
OCWL
  I think she started this channel; https://www.youtube.com/c/AlizeeDefan
A young Asian girl now promotes female musicians from around the world.
p.s., original La Isla Bonita where she dreams of Pedro; https://www.youtube.com/watch?v=zpzdgmqIHOQ
https://www.google.com/search?client=firefox-b-d&q=la+isla+bonita+text+song
"Madonna" ,Madonna Louise Ciccone,her songs ( and audio-video ) are to understand bivalent (terrestrical/ "heavenly"-spiritual ) : https://de-m-wikipedia-org.translate.goog/wiki/Kabbala?_x_tr_sl=de&_x_tr_tl=en&_x_tr_hl=de&_x_tr_pto=wapp
Not a common Pedro but "San Pedro" ! "La Isla bonita" a kind of "Heaven in Social P(e)ace" !
A kind of "love song",for some blasphemy/haeresy !
Sincerely
OCWL
