Build 2
Started by Johnsmith, December 22, 2021, 08:33:09 PM
Johnsmith
 The real AB Hammer; https://www.ksla.com/story/37863650/an-arklatex-man-endures-a-series-of-unfortunate-events/
People in these forums love him. He was never banned from a forum. And he never showed his work. Why he is credible.
Johnsmith
 What is not banned at besslerwheel.com.
Mt 24 is a drawing I like but this guy like many others has never been banned and has no builds to show.
Why am I banned repeatedly for building in this forum and at besslerwheel.com? That's because that
is what frauds do, they build what they post.
https://besslerwheel.com/forum/viewtopic.php?f=1&t=8898&p=186543#p186543
and
https://www.youtube.com/watch?v=V6iDmqOft04
or
https://www.youtube.com/watch?v=GtJct8nKjcc
and
https://www.youtube.com/watch?v=wUoAHtmRrdk
Johnsmith
 A playlist;
https://www.youtube.com/watch?v=kWtcWuKNbag
and
https://www.youtube.com/watch?v=8hVaAnFxtAY
Culture does matter.
p.s., with wind energy, there are wind turbines and sailboats or sails.
That's kind of limited. Now to consider gravity, there must be more
ways, right?
And this is an example of why "keeling" or the "keel effect" is an accepted engineering principle. I probably could've had surgery 7 years
ago but AB Hammer said that he would sue me. And with how posts have been edited, his lawsuit could've made things worse for me.
I will be building what could have been built but as AB Hammer said, he is supported as being credible and posts show that I was the problem
while he was trying to help me.
And the video and its contents are not considered credible because they do not support what AB Hammer, rlortie and Mr. Tim promoted.
https://www.youtube.com/watch?v=zOBQjUEd_4s
And when Mr. Tim talks about his keeling, AB Hammer switched from perpetual motion is impossible to most wheels won't work which is anything I build.
And as he said, it describes why most wheels won't work. I guess he knows of 1 or 2 working wheels? Just word play. AB Hammer gave that example already,
say it's impossible and then say most wheels won't work.
And what they did was to shut down any discussion on how torque could be generated. And as they both said, they don't use math except for measuring something.
This is apparently what Mr. Tim based his keeling on. https://tinaja.com/glib/muse122.pdf
And yet the link I posted states that sailboats often capsize. And with my invention, I'll show how doing the math allows for a simple solution if a person understands
mechanics. And it will be sad what I've had to tolerate from people who ignore math. Even in what Mr. Tim referenced in quadrature
http://www.besslerwheel.com/forum/viewtopic.php?f=1&t=8895&sid=ed940435d15527759fcf82646838b800
the article does not help with perpetual motion unless someone considers what the author said,
Most science students should quickly learn this essential rule: An hour spent in the
library is worth a month in the lab. Same goes for engineers.
And when people won't do the math, as the guy Mr. Tim refers to said, you're basically wasting your time.
And all Mr. Tim considered was 4 weights on a bicycle wheel. That is funny because my first tests were 2
opposing weights on a bicycle wheel. And my experiment let me know that a weight will need to move inward.
And then I started using trigonometry. So yes, I was willing to spend time in the library. And people who
couldn't spend time learning kept saying I was the problem.
And with rlortie, as AB Hammer said, for legal purposes this is only my opinion. I think rlortie wanted people
to tell him how a perpetual motion machine works so he could build it himself. He, like AB Hammer were
private builders who together controlled 2 forums literally. This is because they were also partners in
promoting Mr. Tim's keel effect. And as I've mentioned, why should I have to let people like them dominate me
in a forum where I show my work and they don't?
I'll give an example. Tarsier79, I don't have a working wheel, can you tell me what I'm doing wrong? Did you say to use
a 2nd bicycle wheel like Mr. Tim said and not have it rotate? And that I should tie a line to the non-rotating wheel and
use pulleys to guide it to the weight I want lifted?
Thanks for the help Tarsier79. I sure wish I would've thought of that.
And that is what AB Hammer taught people and what forum owners and moderators support because that is how to help someone.
And now if what Tarsier79 told me to do works, he'll be the one who figured it out.
That's what people will hear and accept because it sounds good and makes people feel good. Tarsier79 was willing to help someone
to build a working wheel who was a failure.
And with Bessler, he said that he did not use a wheel in a wheel. Can you define "in a wheel"? If he placed a drum on each side of the wheel
and had the rim of the wheel wider so it covered both drums, are those drums "in the wheel"? That is what would have allowed Bessler to
cover the sides of his wheels with linen cloth.
And I'd say what has held me up for several years is that people who I consider to be scam artists were considered as credible. And I think
when someone said they'll sue me if I build anything that they should've been banned and yet they weren't. And in the U.S., such a lawsuit that
I was threatened with could've dragged on for a number of years. As things are, I'll probably move out of the U.S.
Johnsmith
 And something obvious that everyone has missed. This includes Einstein as well as Newton.
Because Venus is closer to the Sun than the Earth is, it would be a denser planet than the Earth is.
Neither Einstein nor Newton considered how an increase in the Sun's gravity would affect Venus
more than it would affect the Earth.
Venus diameter is 12,100 km and the Earth's diameter is 12,756 km. Shouldn't the planet closer to the Sun
be denser instead of not being as dense as the Earth? I just wonder how this has been missed by everybody.
Someone gave the answer to this. Gravity acts on everything equally. Why perpetual motion can't work and
why Newton's work doesn't consider an increase or decrease in its effect just as Einstein didn't consider that.
And with something like that, it will change how astrophysics needs to be considered.
So if people think that it bothers me what I have had to tolerate, it does. And yet the people who caused me
problems couldn't consider that Venus is denser than the Earth because it's closer to the Sun than the Earth.
And everyone knows what scientists say. Perpetual motion is impossible. It is if you don't do the math. And
with Venus, the Sun's acceleration of gravity is 1.85 times greater in that orbit than it is in the Earth's orbit.
You know, the Earth's gravity is 9.81 m/s. The Sun's gravity will decrease as you move away from the Sun.
When Einstein said that the space around the Sun is warped, he should've said it's denser. That's what
light bending more than matter when it passes near the Sun from a distant star is about. Yet the people who
attacked me didn't even know these basic things about science.
@Tarsier79, what I will say is that when people like you and AB Hammer say I am mentally ill, why is it the only people
who attack me have 2 English speaking parents from the country they live in? I have to believe it is because I used to
live in Norway and speak Norske. And that is what will get besslerwheel.com banned from the internet. I was attacked
and banned for not giving my work away because I am 1/2 Norwegian. Kind of why I'll move out of the U.S. as well.
Read the 5th paragraph down. What you need to be mindful of is that what's true in the universe is also true in our solar system.
https://astronomy.com/news/2019/10/dark-matter-makes-these-super-spiral-galaxies-spin-surprisingly-fast#:~:text=Most%20spiral%20galaxies%20rotate%20at,contributes%20to%20the%20rotation%20speed.
Johnsmith
 I'm doing a new design drawing for this build. This way I'll know what dimensions I am building to.
Even though I've got a lot of work done, the pulleys will need to be mounted as well as the kicker assemblies.
It is a lot of work. And the people at SketchUp know that I've done a lot of design work and if this build works
then I'll be able to thank them because their program is very helpful.
I think I'm just going to relax and try to enjoy this for a change. It's sad in a way that "real" Americans made this toxic
and forum owners and moderators allowed for it. It shouldn't be a problem working with other people. But then this is
a challenging build.
