Build 2
Started by Johnsmith, December 22, 2021, 08:33:09 PM
Johnsmith
 If what I'm doing works, I might destroy my build and walk away from this (Bessler did). It is that toxic of a subject
and once I can have surgery, I'll have no need for it.
One person was even telling everyone that I killed someone and then to hear ad nauseum "gravity is a conservative
force" like it means something. Yet no one can do basic math. That's basically how cause and effect can be considered.
This is where I think even with a working wheel a lot of people will say fraud. As my "killer" accuser said, they had to
protect their credibility.
And as far as this goes, can I discuss it with anyone? I can't. Who needs that in their life? Nobody I know.
Once I have it mostly completed, maybe still needing the weights to be poured I'll make a quick video using my phone.
Then I can be ready for when I get my new video camera and make a decent video.
kolbacict
QuoteThis is where I think even with a working wheel a lot of people will say fraud.
Without a doubt. They are such people ... I know it by myself experience. :)
QuoteWho needs that in their life? Nobody I know.
I know one such person. This is me. ;)
conservative forces when work in a circle, when we return to the starting point is zero. It seems so?
And when there are two separate masses,
moon and earth, it is really possible to get a profit there.
And I think people have been using it for a long time.
Tidal power plants, for example.
Johnsmith
Quote from: kolbacict on January 17, 2022, 01:47:45 AM
Without a doubt. They are such people ... I know it by myself experience. :)I know one such person. This is me. ;)
Okay. With gravity, I consider it a directional energy flow. And as you mentioned about wave/tide generators, strong and weak gravity
fields.
With what I am building, it is going well. The 2 lines show how the retraction lines will cross. This is important to understand. This is
because when the line goes from the larger pulley to the retraction disc, it needs to be at 90º to the axle. This allows the retraction
line to maintain its relationship parallel to how the weight wheel assembly moves up the arm.
I will be able to set it up to do some testing but will need to get different lag screws to cut for the pulley axles. That's not an issue as
it will be next month when I can make the other 4 weight wheel assemblies. For basic testing I'll freeze water in bottles. This will provide
the extra weight/mass needed to see how well the wheel will rotate with 8 weight wheels on it. And then if it can't rotate 45º, more math
will need to be done.
Why 45º? After every 45º of rotation a weight wheel will roll out while the weight wheels in the bottom left will move inward on their
respective arms. And if the wheel rotates 45º then it could work when it is finished. At the same time, it would rotate more quickly if I add
2 lbs./1 kg per weight wheel. And after that if it still doesn't work, I'll build an easier to understand perpetual motion machine.
p.s.,  The way the retraction lines will be connected to 2 fulcrums some people will find confusing. Yet this is necessary if it is to work.
A couple of fotos showing how I am building my weight wheels. A rectangular weight will go on the inside. I had made some spacers out
of a round oak dowel and will need to find them. While the weight wheel is off from one side to the next, this is a prototype so that's okay.
If it works then a better wheel can be built or this one can be overhauled or both.
And if I need to add more weight, another round weight can be placed behind the weight with the wood square in the middle. The way I
am building it will allow for that.
Johnsmith
 At the moment I'm making spacers out of oak for my weight wheels. I'm also ready to start pouring new lead weights.
Nylon bushings can be a bit expensive and I have the time. I have enough pulleys on the wheel for testing. And my camera
is about to be shipped. I'll finish placing the round dowels for the pulleys. I usually have to hand sand their locations so
they'll fit. I'll probably need to buy more lag bolts. They have a smooth shank which I use for the pulleys to ride on. I
should've bought longer ones.
And since I do have my own build that I'm working on, with the 2 oscillation/Malkovic pendulum, maybe thx4 or kolbacist
will consider it? I'll be showing 2 different ways that might work. One will use gears while the other will use pulleys and leverage.
p.s., with the block that is clamped down, when on its narrow edge, I can saw the spacers. Then when it's lying flat, I can drill them.
I do have a miter saw and a drill press, I also have a neighbor as well so I do need to be quiet.
kolbacict
