Build 2
Started by Johnsmith, December 22, 2021, 08:33:09 PM
Johnsmith
 Thnaks kb.
With some of the work that I've been doing, how the wheel rolls on the arm. I'll need to make some adjustments
but have time. With the weight wheel, I had to file down the lead blanks so they'd fit. I need to get me a table saw
and a router table. Maybe in the next month or 2.
And next week I should be posting a video of testing this concept. I might do 3 different tests. In the video I would
explain why each one matters or how they work together to show what I'm doing.
Johnsmith
 I've got all of the weights seated in their frames. I should have my camera tomorrow. This means that
I should be able to make some videos this weekend which I can edit into 1 video. It would show why
45º of rotation have the weights shift so the sequence can be repeated.
And with that, also a test showing how 2 overbalanced can rotate 2 other weight wheels. That would
show where torque is being generated, After that, tests would be to determine how much weight on
each weight wheel would be needed to rotate a complete wheel. I know it is slow going but this is to
ensure that each step leads towards a working wheel which is the ultimate goal.
Johnsmith
 I got my camera today and I'm looking forward to making my next video. My local library has Apple computers with Final Cut Pro 10.
I've got a decent amount of experience using their software. I will try to explain why I think this is Bessler's wheel and why I think it will work.
With what Bessler said;
Around the firmly placed horizontal axis is a rotating disc (low or narrow cylinder) which resembles a grindstone. This disc can be called the principle piece of my machine. Accordingly, this wheel consists of an external wheel (or drum) for raising weights which is covered with stretched linen.
https://besslerwheel.com/writings/das_triumphans.html
The disc that I am using to lift weights with is a 1/4 section of a round drum. Instead of the drum rotating, the wheel does. And this causes a line
to wrap around the 1/4 drum section in the same way it would if the 1/4 drum section were rotating. And this is where "free energy" comes from.
Because no work is being used to lift the weight closer to the axle, it decreases counter-torque. And this is what I plan on demonstrating.
With the 3 drawings, the line is wrapping around the green part of the drum as the wheel rotates. The weight that has moved towards the axle is
still the same distance from the top right corner of the green area. And with where the line goes towards the bottom of the green area, it is
maintaining a right angle to the axle of the wheel. This is a necessary relationship that needs to be maintained. When the wheel is rotated 45º
(2nd image), that same relationship exists.
kolbacict
http://www.youtube.com/watch?v=U3XfSe_LAFA
Has english subtitles.
About how the boy found a way out of what seemed like a hopeless situation. :)
Johnsmith
Quote from: kolbacict on January 23, 2022, 07:41:24 AM
   In a way the King in the video is like a group of people who controlled this forum and besslerwheel.com. They
would say you don't know how perpetual motion works. And if the reply was "I am working at it" then they would
say prove it to me.
There are ways that conservation of energy is possible but they needed it to be called "perpetual motion". And
with the situation that I am working through, I needed to be able to work with someone. But now I have a room
where I can build.
I think though in a way Tsars could be replaced with scientists who want to laugh at people pursing a way to conserve
energy. The basic mistake that scientists have made is saying that while gravity is a force it has no energy. And this is
why they say the Earth's gravity cannot be conserved. Conservation of energy requires something to have energy.
If gravity has no energy then it cannot be conserved. Since f = ma which suggests that gravity has energy. But energy
would be considered as KE (kinetic energy) = 1/2mv^2. This would be to suggest that space has mass.
From here we jump to why light bends more when passing by the Sun than an asteroid or other celestial body does
than what Newton's gravity allows for. Since light interacts equally with space and time, what space is it interacting with?
And now we can wonder, does gravity have energy which we observe as force? If so, can it be conserved?
p.s., A historical fact. And guys even kolbacict might not know this. The city of Yekaterinburg, Russia was founded by a man
from France and a Russian. In the 1800's Russia basically stopped at Perm so 2 guys traveled across the Ural Mountains to
avoid paying taxes to the Tsar.  Yekaterinburg as a result became a center from processing ore.
Now you guys can wonder how does someone living in Kentucky, USA know this?
