Build 2
Started by Johnsmith, December 22, 2021, 08:33:09 PM
Johnsmith
  With this design, lead rises as it sinks......in water. And we know lead doesn't float. Then it can't rise as it sinks because
lead can't do 2 opposing things at the same time, right?
When lead sinks, it pumps air. Then because the bellow it is associated with will either sink or rise. It's pretty basic. Blow
the ballast tanks on a submarine and it rises. Fill the ballast tanks with water and it sinks. If you don't want to land on the
seafloor then air has to be left in the ballast tanks to maintain some buoyancy. That is how a submarine can hold position
at any given depth.
And some will say this can never work because lead doesn't float. And this is what I call my "fail safe". Professionally built
by a respectable wood worker, people will take notice. The issue is the tank. A small tank 40 in. x 40 in. x 18 in.
(1m x 1m x 45cm) holds .45m^3 of water or 118 gallons that weighs 990 lbs. or 450 kg.
That's why I can not build that at home if it is to be built right.
With my Bessler build, I'll probably put pulleys at opposite ends of a crossbar to show that the overbalance allows for both
sets of weight wheels to be lifted when it rotates. Bessler shows working together in so many of his drawings that anyone
familiar with them would find this is something that Bessler taught in his maschinen tractate and the first image that you
see might actually represent how retraction lines are connected. And I don't expect anyone to understand that.
http://www.orffyre.com/mt.html
p.s., with this, think Jules Verne 20,000 Leagues Under the Sea. Wood, copper and neoprene.
p.s.s., as for the Bible, since I have to give what I have to AB Hammer, that means it is now a sword and a shield. Yet Jesus
said do not bother people and be known by your walk. And because that does not describe Christians in the U.S>, I will need
to move to another country so I can have a life. It's like a famous baseball player (Yogi Berra) said about a restaurant;
Nobody goes there anymore, it's too crowded.
That describes the U.S.
p.s.s., 2 months ago I had less than 30 subscribers. My channel is more about documenting my work. With what I'll  probably
do to my prototype is shorten the arms so it can be on its stand in a spare room I have. Weights being lifted when they're top
center will generate a lot of torque. It will just be testing a theory that resistance does not consume energy because it is not
doing any work. And yet some idiot will say the weight is moving. It won't be moving. The arm it is on will be moving away from it
so technically the weight on the wheel is in the same position as before to its fulcrum.
With the underwater water wheel, lead is about 10.3 times denser than water. Water is about 816 times denser than air.
When lead is attached to a bellow or a float, then the total weight and volume are considered as one object or mass.
https://letstalkscience.ca/educational-resources/stem-in-context/why-do-ships-float
Johnsmith
 My channel will determine what I do and when I do it. Next week I'll make a video showing both of the wheels that I've built.
The Ode to Bessler and the prototype. And I will explain how I'll test how torque can rotate a wheel and show how the weights
are moving because the wheel is moving and not the weights.
This is basic cause and effect which goes back to Newton when he published his book En Principia for short back in 1687.
Philosophiæ Naturalis Principia Mathematica. Bessler was 7 at that time. You could almost say that Newton's book in Engleske is
The Philosophy of the Natural Principle of Mathematics. Or how does mathematics allow us to understand our solar system?
That's basically what the title suggests. And physics is actually based on his literal title.
The 2nd video will show if the prototype has enough torque to rotate a wheel that lifts 2 weights. This is because gravity acts
on everything equally and the drum is not lifting the weights as Bessler said it is. He said what you would understand but the drum
doesn't rotate and the wheel does.
And then for fun we can consider math and what it allows for. When physics and mechanics meet, it is called engineering.
Physics does not allow for flight while engineering does. Physics is as Einstein said, to understand Odin's thoughts.
Engineering perverts the natural order of things.
Unless someone has specific questions about how lead can float or an airplane can fly, I'll need to focus on my next video. And if
you've ever gone fishing, you know the bob (float) doesn't sink unless you have a lot of lead weight on your line. Interestingly
enough I have fished from the fjords of Norway to the Puget Sound in Washington State, USA. I've lived in both places.
Johnsmith
 If you like Rock music, there is this; https://www.youtube.com/watch?v=_B90VnG6FR0
And what my mother would've loved; https://www.youtube.com/watch?v=PQ7vU401MrA
With perpetual motion, it is about conservation of energy. It is about converting energy
from one form to another. With music, strings and vocal chords change how the air moves.
Sound is nothing more than molecules vibrating. No speaker puts out sound. It transfers
kinetic energy to molecules in the air. Sound is never produced. It is only perceived.
And just something else for you to perceive;  https://www.youtube.com/watch?v=d3jcOWp71-Q
She is training to be an opera singer and she is French.
And since her goal is to sing in the opera; https://www.youtube.com/watch?v=zZJr8rZcoiA
This is a perpetual motion forum and in calculus limits are set, why do we set limits?
How you know, how to find limits in calculus; https://www.youtube.com/watch?v=nJZm-zp639s
What hurt me was not having a text book with homework assignments. Those would be helpful.
And as we all know, music Rocks!!
p.s., math helps us to understand values in mechanics. Kind of why we know why something moves.
https://www.youtube.com/watch?v=fSlEIzSwVho
Johnsmith
 Nazis didn't kill my father. He could run faster. And perpetual motion is impossible. It is.
And I've asked a Jew to work with me. It is a fücked up world. She knows my situation.
It's a different world today. https://www.youtube.com/watch?v=Nco_kh8xJDs
It is a different world today. People need to learn to work together.
ie., power comes first. Those who do the work, it is to show to those in power.
p.s., if I was born 20 years earlier; https://www.youtube.com/watch?v=XKCDc8Eg_-U
Today we need to know math. In the 40's and the 50's, in the U.S. they were called nerds.
Times have changed.
Johnsmith
 I'll be needing to buy some plywood. I'll need to make a "ring" around the outer part of my build. Then
it will look like an actual wheel. This is because I'll need a place to mount pulleys. Then this will fit another
part of the description of Bessler's wheel. A curved board was placed around the outside of it so you
couldn't see past it. This made the frame rigid. Otherwise the frame could twist and break.
I'll be making a video of with what I showed in here and explain the modifications I'll be making to my
current build.. I'll also show where Mt 24 shows a shift in force that is unique to Bessler's drawings. And it is
also in 8 sections. Witnesses said that they heard 8 knocking sounds per revolution.
With the modification I'll be making, I'll only lose 3/8" or about 1 cm of overbalance. And since I'll be needing
to rout parts that will be 32" (81.25 cm) across, I'll only be able to work on those parts on Sunday when my
neighbor is in church. And I will need to make numerous small parts so the left and right side of the frame
can be connected so they'll be rigid. That will mean a lot of gluing and letting glue dry which will slow things
up as well. If you consider trusses, just a basic truss will be needed. When it's built everyone should get it.
And this is kind of why I want to enjoy all of the work that I'm doing, it is a  lot of work.
p.s., I had 2 credible individuals tell me that they would not let me pursue perpetual motion.
I always had the same answer, they tried to stop Rock and Roll and they failed.
https://www.youtube.com/watch?v=4OFESufsZG0
