Milkovic's Pendulum
Started by Johnsmith, January 11, 2022, 09:36:24 AM
kolbacict
Excellent. It remains only to do. ;)
Cloxxki
While less and less convincing devices are shown and ever fewer and less convincing words are added by the proponents...
What is the SINGLE MOST IMPRESSIVE device demonstrated or arrangement correctly calculated? Show us the best of the best of the Milkovic magic? The most promising readings, closest to equal energy in and out, I guess?
kolbacict
I once tried to combine a Milkovich pendulum and a V gate magnetic motor . ;)
If Milcovic's double pendulum is multiplication of force, then it should be  to Increase the pull force of the long magnet mounted on the lever from the rotating drum at the moment of transition. To avoid sticking. But my device don't had rotating itself.   :(
Cloxxki
If the Milkovic water pump really were 12x efficient, it would fill up a bassin of wanter higher than its first stage, and a value opening and closing would be driving the first stage, easy enough the time. Water under pressure existing the bassin horizontally from a pipe, intermittently to match the phase of the first stage. The second driving would drive a water pump that pumps more water up to the bassin where the water level would be ever rising, and the 2-stage pump ever working.
As I wrote elsewhere, we need to get rid of empty overunity claims. In solid state electric systems, as little as 10% overunity would make the absense of a serious looping and constant output attempt unacceptable. With water splashing, 3x seems more than worth giving the loop a go. Different mediums, different looping thresholds.
seychelles
