Permanent magnet assisted motor coil designs
Started by captainpecan, January 24, 2022, 02:35:06 AM
captainpecan
@jimbo,
Ahhhh... the orbo experiments. I remember now. I was looking into that concept a bit many years ago. I've been away for while. Just getting back after a long break recently. That stuff was very interesting and I watched all the videos but never did a build to play with it. I would be very interested in seeing your work if you do any builds to work with this. I may work a bit on it myself after I have moved forward more with my current project. I'm still waiting on my new power supply. Hopefully it will be here monday. It will let me pulse up to 120v DC and 800 watts if I wanted to. If I can't find a pulse amount that releases the hidden permanent magnet force, then it just isn't going to work as predicted. It should get it done if it will work at all.
synchro1
The "Orbo" is an attraction neutralization motor that positions the toroid coil at the neutral zone between the NS rotor magnets so both poles of the toroid coil power the release.
captainpecan
@Jimbo,
You bringing up this orbo concept again into my mind, made me realize I need to completely change my test setup for my current motor I am building. I have been testing the magnetic field coming from the coils in relation to the power supplied. That is handy. But the build will be using magnets on the rotor to propel away when the internal permanent magnet field is released. The orbo work made me realize, the inductance will probably change greatly when the rotor magnets are in line with the coil changing the entire power curve I am measuring. Maybe it will then require less power to release the field from within? Don't know. Time to build, amd do pull tests measuring pull strength as power is supplied to see what happens when I hit the sweet spot voltage. I guess gauss reading only helps in coil design, but still doesn't tell me much about what will happen when magnets are sitting just past TDC. Can't wait for my new power supply. I feel like a child waiting for Santa to bring me my toy!
synchro1
JLN's Lambda of 13.7 expresses the advantage. The magnets generate a charge from the quanta in the nanoperm core as they fail away.
