Converting mass responsible for Dark Matter into Energy
Started by MGsid, February 23, 2022, 05:30:56 AM
e2matrix
Here is something that may be related although it looks more complex.  Attached patent appliction for Dark Matter motor / generator
MGsid
Yes, it does look a bit more complex. Device in my presentation should be easier to built. It can be even built as Tesla coil with little modification and there is a lot of people who know how to build Tesla coil.
Phi(1.618 and 0.618) is also a harmonic number and it can be applied to this concept. The reason I use 6/5 harmonic is because it is smaller and device will have smaller diameter. Even with this harmonic with eight steps (wavelength * 1.2^7)^2 it should produce about 12 times more energy on the output.
ovun987
MGsid
Glad to hear that. Tomorrow I'll try to post some pictures.
MGsid
Ok. This is what I've made so far. As I've said, it is just modified Tesla coil. The difference is primary coil which is made out of 9 rings with 6/5 harmonic relation to each other. This will give (wavelength * 1.2^8)^2
The plan was to use two coils for energy generation. One above and one below primary coil. The upper was meant for feedback loop and lower for useful energy, but I was unable to create feedback loop. The reason, I think, was that I've tuned the secondary to primary frequency (751 kHz) and it should be tuned to primary * 1.2^8 which is the frequency of the field in the center. This gives me about 3.23 MHz
If I was to do this again, I would use one tripole coil tuned to 3.3 MHz and tried to create feedback from there.
The HV transformer that powers primary is about 200 W and with this setup (wavelength * 1.2^8)^2 there should be around 3 kW in the center.
