0 Members and 18 Guests are viewing this topic.
SolarLab
Quote from: bistander on December 20, 2022, 08:47:24 PM
Hi SL,
As long as you've gone off-topic into pettiness, how's this one? In your post to Pm, shown above, you say "Remant Flux Density (Br) [Coercivity of material]"
I assume that you meant to type the word remanent. As see here:
Also note Remanent flux density is not the same as Coercivity of material, which your statement of  "Remant Flux Density (Br) [Coercivity of material]" seems to imply.
The two quantities are clearly shown on your included B H curve.
I noticed this before, but didn't want to appear petty, until now.
bi
Ref: (Br)
https://www.arnoldmagnetics.com/wp-content/uploads/2017/10/Designing-with-Thin-Guage-presentation-1.pdf
Read it again for comprehension and Note the square brackets... now, refer again to the B-H Loop and the
Arnold Magnetics Technologies presentation above.
And you still look for "Petty" spelling, etc. stupid shit!
You gotta do better than that - thought you claimed to be an engineer!    Quoting Wikipedia - seriously... LOL
From the Arnold Magnetics Technologies presentation:
• Even when the field reaches zero (H=0), there is still some induction remaining in the[/font]
material. This is called the remanant flux density, or Br.
[/font]
[/font]• To bring the induction in the material down to zero, the H field must be driven past[/font]
zero into a negative value called Hc or HcB -- this is the "coercivity" of the material.[/font]
seychelles
THANKS FOR SHARING. VERY TECHNICAL BUT VERY USEFUL INFO.
I SUGGEST THAT 3D PRINTING THE SILICON STEEL SHOULD CUT A LOT OF
MANUFACTURING PROCESSES.
SolarLab
Quote from: bistander on December 20, 2022, 08:13:58 PM
SL,
I know the answer. And I know electric machine fundamentals, theories and design practices as well as materials, fabrication and testing. I was trying to help. That's all. Why are you beating me up? Let's get back on-topic and look at where on the B H curve Holcomb's device functions. That's why I've mentioned a FEMM 2-D cross section of the magnetic circuit. There would be value.
bi
bi,
F.Y.I. The B-H Curve is absolutely dependant on the "Material" used for the so called Rotor and Stator. Therefore, you must first
select a "Material" for your device before you can look at where on the B-H curve Holcomb's device functions. This is the first part
of the four I mentioned earlier and probably the most difficult part. A fifth part has also been added. This involves fabricating the
rotor and stator (see the 33W Diode Laser Cutter post).
A good reference (one of many) is the book "Introduction To AC Machine Design" by Thomas A. Lipo, referenced here:
https://www.overunityresearch.com/index.php?topic=4261.msg98963#msg98963
All the chapters are worth a read and chapter 2, 3 and 4 provide accute insight. {pdfdrivedotcom}
Also, with respect to your FEMM diagram; there are a variety of Ansys youtube videos out there that provide some good
detailed information as well.
Appreciate your trying to help - but beating up on a guy who is in the middle of a war with only sparse access to power
and the internet didn't sit well with me - so I speak up! [rakarisky]
SL
SolarLab
Quote from: seychelles on December 20, 2022, 10:33:25 PM
Hi Seychelles,
That would be great but to date I haven't found a Material that can be 3D Printed that comes
close to Silicone Steel performance. Maybe some time soon a 3D Print material will be developed.
The closest scheme so far seems to be the Diode Laser Cutter and Arnold's Thin Magnetic Metal
to create a laminated core. Lots of layers but doable in the Lab on a reasonable budget.
SL
bistander
Quote from: SolarLab on December 20, 2022, 09:16:55 PM
Ref: (Br)
[/font]
Thanks SL,
Same information that I learned years ago when I worked with their application engineer. So are you telling that you walk away from that article thinking that remanent induction is the same thing (meaning the same value for a specific material) as its Coercivity, or that Br = Hc?
O.K.
bi
ps. Noticed something really picky. Where you say "negative value called Hc or HcB -- this is the "coercivity" of the material.[/font]"
It's not HcB. It's Hcb, I believe. I'm not too familiar with the notation, but did find this example attached. From: https://www.asa-7.top/products.aspx?cname=properties+of+permanent+magnet
