Ufopolitics
Quote from: listener192 on December 29, 2022, 11:38:41 AM
Ufopolitics,
You say you "worked on these systems".. what does that mean?
L192
Obviously you have not read just the first post on my Thread dedicated to these systems*
*Systems to Generate Electricity based on moving just the Magnetic Field through steel cores and copper windings.
https://overunity.com/19085/energy-generation-by-moving-mag-field-through-static-steel-core-copper-coils/
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
listener192
Quote from: Ufopolitics on December 29, 2022, 11:51:34 AM
Sorry, I am not capable of memorizing the total content of all the threads on this forum, so thanks for the link.
OK, but how does that work relate specifically to Holcombs devices?
Ufopolitics
Quote from: listener192 on December 29, 2022, 12:08:18 PM
It is exactly the same system principle, the same principle as Pierre Cotnoir, the same system as Clemente Figuera back in  1902-1908 Patent...etc,etc,etc...
It is all about Moving just the Magnetic Field, not the Coils, not the Steel Cores whether it be an Outer or Inner "Field Rotor".
As it don't matter if we rotate or displace the Field linearly or in a circle...or in ANY other geometrically possible imaginable shape or form...even Elliptical, or square, pentagon...the Field would still make any complicated radical turn, and very fast, whether in 2D or 3D...without the need of any "bearings".
Point here, it's been done before...way back to 1902 - 1908...
I have also Threads on Energetic Forum that date back as far as 2016...and before.
On a separate note...yes there are thousands of Threads here...however, I know perfectly well (as I know many here) how to disguise/filter what is good and what is plain BS...
Sorry but am too busy now...so, please, let's kill it here. Thks
Ufopolitics
―Leonardo da Vinci
SolarLab
 Happy New Year Ufopolitics
CONGRATULATIONS - Your thread has been cited as "The Best Thread of the Year for 2022" by the little known
adhoc bunch - the "Society for Advanced Energy Concepts (SAEC)."
Excellent Work all around including your Builds and some Great Insight!
Thanks from everyone involved for sharing your exciting projects!
Ufopolitics ---    Topic: Energy Generation by moving Mag Field through Static Steel Core & Copper Coils
https://overunity.com/19085/energy-generation-by-moving-mag-field-through-static-steel-core-copper-coils/msg565511/#msg565511
Notables:
Ufopolitics:  (Re: Energy Generation by moving Mag Field through Static Steel Core & Copper Coils)
« Reply #47 on: May 28, 2022, 08:04:39 PM »
https://overunity.com/19085/energy-generation-by-moving-mag-field-through-static-steel-core-copper-coils/msg567495/#msg567495
"I have decided to migrate my Post from Holcomb Thread here...as I will show further developments in a near future:
A Brief summary...
We need to work more on our Developing and Research "Techniques"...As "enhancing" our "Powers of Deeper Analysis"...please, let me explain..."
The "Secret" - "Not collapsing the Main Field...but harvesting it, feeding it, while mutating only minimal small chunks to stimulate a movement...a Rotation."
"WHY in this World DO WE STILL NEED A "STATOR-ROTOR-STRUCTURE" (or simply put: a Two Part Generator) where the so called "Rotor" does NOT Rotate??!!... "
VIDEO DEMONSTRATING VOLTAGE 2X OVERUNITY
https://overunity.com/19085/energy-generation-by-moving-mag-field-through-static-steel-core-copper-coils/msg568549/#msg568549
All the Best to You and Your Family in the comming Year!
SL, SAEC, et.al
bistander
QuoteVIDEO DEMONSTRATING VOLTAGE 2X OVERUNITY
Nicely done video Ufo,
But it does not show "2X OVERUNITY". You say near the end that the scope shows power, then slightly later, energy. That is incorrect. The scope was displaying voltage, as you correctly stated early. There is no OU (meaning more output power than input power) with a simple voltage increase. Transformers do it. And that is basically what you demonstrated, a transformer with approximately 2 : 1 turns ratio.
Your test was conducted with a open circuit output, or at no-load, right? So power output is zero. So DUT efficiency = 0 as seen on the video.
Nicely executed device. Really clean and smooth. Well done.
bi
