nix85
Quote from: SolarLab on June 20, 2023, 09:11:45 PM
Nix,
Just to shut you up and hopefully get rid of you:
1. MuMetal does what? - It shields magnetic fields!
Why use it? In the LinGen, it shields the pulsed created sliding magnetic
field created spurious signals from the sensitive RF/IF/AF circuits (RF uV input
for example). Do a Fourier Analysis of the LinGen Controller signals and it will
become very clear why they need to be shielded from the RF.
In the rotating generators Holcomb developed he used MuMetal to shape the
magnetic fields.
2. Why use an Inner Stator? - One stator gives you a factor of X1, two stators gives
you a factor of X2 for the same amount of fixed rotor fields. Since the system is
round, it's hard to get more than X2. Unless:
By using many concentric rotor/stator stacks allows taking advantage of the full winding
of both the rotor poles and stator lap windings (somewhat similar to the Gramm generator).
3. Lenz, or rather BEMF, a.k.a. Generator Drag reduction? - By not having the live
rotating magnetized rotor sweep past the stator the Lenz effect is mitigated. This
can also be controlled in a stationary system by the control sequence (truncation),
amongst other methods.
Now, with the LinGen; you can stack them (they're flat) and use other interesting
shapes and combinations.
See, not that hard to figure out was it... but you have to study and analyze it!
I'm sure you still want to argue but go off to another thread and argue with some
else, please...
SL
Little pest like you can only dream about shutting me up and getting rid of me.
There, after how many, is 3 or 4 months i've been asking him to answer these basic
questions, he, or should i say, it, yields, but again only junk.
1. MuMetal shields magnetic fields... you don't say :)
Now you mention RF, and where does Holcomb ever mention using RF. In the patent you linked there is no mention of any high frequency/RF and in the videos he says clearly he uses low frequency, around 125 Hz. I am not excluding his controller is using RF PWM, shielding the controller is irrelevant subject-wise.
As for your second sentence "In the rotating generators Holcomb developed he used MuMetal to shape the magnetic fields."
Again nothing concrete, what exactly is shielded, the secondary or, how much. And i am not going to ask you for you do NOT know. Have you taken the Holcomb generator apart and seen it first hand, you have not, you got patents and videos to go by like everyone, in other words, you have no idea what you're talking about.
2. As for Inner Stator....so you are saying inner stator is aiding the outer stator (so not N-N). Ok, let's say that is so, double the field double the induction, that is obvious.
As for "many concentric rotor/stator stacks allows taking advantage of the full winding" more bs. "Many", where are those "many", there are 3 layers, inner and outer stator and "secondary" sandwiched between them. This design alone is not overunity.
3. And your "explanation" of how lenz drag is eliminated is total bs too
Lenz can be mitigated in various way and it is not hard if one studies and analyzes INDUCTION and understands it deeply in all its forms...
...but lenz drag is surely NOT eliminated by the mere fact magnetic field is not physically/mechanically rotating. It is ridiculous and STUPID to claim lenz drag is eliminated like this. Lenz's law applies fully just like it applies in a transformer.
I have already suggested he MAY be using delayed lenz ala Heins, but the problem with that is he is using low frequency (around 125Hz if i remember correctly).
I don't want to argue, you idiot, it is exactly you who has been arguing with people for asking sincere question here since the beginning, i am asking sincere key questions that must be asked (and have been in part asked by users here but you never answered, only attacked them for asking) and answered clearly if this device (or any overunity device for that matter) is to be correctly understood and replicated,
And SL,
YOU ARE CLEARLY AN ABSOLUTE IDIOT...WITH NO TECHNICAL SKILL OR UNDERSTANDING
Here is a link - just for you
https://overunity.com/19069/holcomb-energy-systemsbreakthrough-technology-to-the-world/msg579164/#msg579164
BTW  You did not learn the namecalling and other "childish behavour" from me, your posts going back to the beginning of your Holcomb circus year and a half ago ABOUND with namecalling and tantrums and i have recently quoted some of it.
SolarLab
Nix,
Too bad a Rocket Scientist like you couldn't figure this stuff out
without having to be told!
For a Guru OU guy you really don't show it!
Oh well - keep up the fair work...
SL
Lottalead
Quote from: nix85 on June 20, 2023, 09:13:11 PM
Hi Lottahead, i am indeed enjoying my day! Wish you were too!
Firstly, i am someone who studies and works with overunity profoundly. I already know of many overunity principles altho i have not yet built one, but at this point it is mere question of funds, not knowledge.
I have studied deeply deeply deeply for many years to be here, both conventional and overunity side. So i know there are better methods. With that said, i am interested in it (Holcomb) enough to sincerely look into it and ask the key questions which are indeed key questions which i did, not "key" questions, but KEY questions. No need to repeat them and there are others too.
Besides, i am not talking about Holcomb at all anyway, i never said he had to reveal details about his tech. Never said that, never implied that.
Fact is Holcomb only vaguely hinted at the method he uses - geometry and shielding. There are dozens, hundreds of other overunity devices outthere about which FAR MORE IS KNOWN. Many of them in my playlist.
https://www.youtube.com/playlist?list=PLS6CmWwu5VGmYsgX5-2kFtPsE-iIsXj_o
And when someone claims to "know" / "understand" exactly how Holcomb's device works and at the same time is incapable of answering even vaguely, even in general manner, even the most basic key questions about it, then something is rotten there.
You are clearly a 100% non-technical person, fanboy (fangirl?) who only acts as some kind of "moral support" for something you have absolutely no knowledge or understanding of. Instead of "attacking" (in a clumsily masked way) those whom you misperceive to "attack" Holcomb (which i do not), invest your time more wisely, for example - educate yourself about electronics and overunity principles, maybe then you will be able to actually hold a valuable conversation about these matters.
You and your newbie colleague who also has nothing smart to say but pollute this thread with "cheerleading".
Enjoy the evening!
Nix
Nixxy boy... come on now.. hush.... lets take it bit by bit..
Firstly... I don't care who you are...
.. I don't care what you studied...
.. :) if your not talking about Holcomb and his tech, why talk at all?
.. there you go .. not talking about Holcomb again..
.. nope not going to open your link.. its irrelevant to the discussion here of Holcomb's tech
... there you go talking about someone talking about Holcomb..
.... Don't care what you think
.. don't know anyone on this thread..
Holcomb's technology is finally coming to market.
It will benefit all.. even you
I'm living the dream Nixxy...
LOL
LL
nix85
SL, since you love sarcasm so much...
Lucky for us all that an OU guru like you has figured it all out
and explained it all so perfectly.
So, just keep up the fantastic work, God speed.
Nix
nix85
Quote from: Lottalead on June 20, 2023, 10:08:02 PM
LOL
LL
Lottty boi, or is it a Lottty girl.. hush.. here, i'll break it down for you...
.. Firstly, i care even less who or what you are...
.. I don't care what you care about...
.. There :) ofc you stupidly did not get that by "i am not talking about Holcomg" i was saying i am not criticizing Holcomb, as i clearly noted, but am only saying if someone here CLAIMS he "knows" then the least he can do is answer sincerely some basic questions about it..
.. Don't open the link, it's all "irrelevant", don't educate yourself..
.. There you go talking more junk and still not educating yourself...
.. Don't care what you think either
There, finish it with blind faith in something you do not understand, but don't ask questions about how it works and by no means do not educate yourself.
Keep living a dream Lottty princess, but dreams turn into nightmares if not backed up by hard work and Knowledge, Lottty...
Nix
