onepower
Rakarskiy
QuoteHolcomb is a very successful MD, not an electrical engineer. In fact, those people who have visited him note that he operates with his own concepts rather than the traditional terms of electrodynamics and electrical engineering.  The main thing is that he performed his generator in reality, and even in several hypostases. He also has a dynamic motor-generator converter with COP-4,0.
Indeed, I found this to be true as well. Most successful FE inventors developed there own concepts first then tried to explain how it applied to conventional wisdom. They don't replicate stuff they invent new concepts and test them. As well, almost all FE inventors started with motors and/or generators then progressed to motionless systems. As such Holcomb's progress is very similar to all the other FE inventors.
QuoteQuestion, what prevents him to produce a small batch of 5 kW devices and sell, with the stamp "for scientific testing" without warranty and after-sales service (I know such episodes).  This just shows that he knows the system, how it will react to such a move. He probably inherited the center (I had that info, I didn't check it) and they worked in the system, repairing electromechanical equipment motors/generators.
I agree, one would think the science community would be all over this but there not. Even the mention of this field of technology can get a scientist blacklisted. I was in the physics forums for a while doing psychological research on them and they display strange behavior. They seem to follow the primitive pattern of behavior of the "the crowd" described by Gustave Le Bon in his work. Hostility to new idea's, cherry picking facts, denial and then psychotic behavior when they don't get there way. I concluded it has become a cult of sorts demanding everyone think and act the same... not real science.
I think Holcomb is on the right track. The trick seems to be to remain independent not relying on others. As it stands they are an independent corporation beholden to no one. There customers and everyone else can take the technology or leave it and it makes no difference. If they don't like it don't buy it and nobody has the right to tell us what we should or should not be doing. As well, it's magnitudes more difficult to attack a corporation versus a person. People come and go but a corporation is not a person it's an entity.
AC
skybiker63
With the support from a professional electric motor construction and manufacturer I would like to create a testing unit.
Could anybody help and support us that we spend not too much useless money into the project ?
How about the book from Rakarsky...
I would like not to do the same mistakes as Holcomb did, still wonder how Clemente Figuera managed it more than 100 years ago....
I think the HES has a high base load. A single effect is only produced if the base load is significantly exceeded. In other words, the HES does not regulate itself according to the load, but operates within a fixed consumption window.
This would explain why it works and does not work in different circumstances
rakarskiy
Quote from: skybiker63 on July 05, 2023, 01:21:39 PM
Start with the simplest generator. It can be made both with magnetic rotating rotor and with solid state. Instead of magnetic rotor insert an armature with statically placed windings and a brush-collector assembly, where to rotate the brushes around a static collector with lamellae. You can even make two identical stators, one with a mechanical magnetic rotor and one with a solid-state rotor and compare them.  Take the cores from microwave fans. I have stated everything in plain text. Just do not think that it will be easy to calculate the phase.
https://rakatskiy.blogspot.com/2022/06/overunity-holcomb-energy-system.html
Kromrey is the same flux-switching generator, only a more unfortunate design. It is easier to place magnets and windings stationary and rotate only the core-switching generator.
https://rakatskiy.blogspot.com/2023/05/blog-post.html
Lottalead
Quote from: onepower on July 04, 2023, 05:08:27 PM
Lottalead
Indeed, having been in the FE tech loop it's amazing Holcomb got this far.
Usually large corporations or investors set up fake foundations, investment groups or shell companies to acquire FE technologies. Once they have control they run them into the ground, bury them or bankrupt them with fake law suits. It looks like Holcomb may be playing it smart by acquiring a few credible investors and building the company on sales. It's slower but in the end the odds are magnitudes better they could succeed.
On claims the technology doesn't work. This could be the case but in many cases bad actors simply buy the technology, sabotage it then spam the internet with bad publicity and file fake law suits. Why wouldn't they?, if I wanted to ruin your company that's exactly what I would do. I would hire some dim wits to buy every unit unseen, sabotage them then file as many laws suits as it takes to destroy the company. Hell, I could even hire the same dim wits to spam every internet site claiming it doesn't work and it's a scam...easy peasy.
I think Rakarskiy nailed it with his last post.............
It's that simple, either we can solve the problem at hand or we cannot. However blaming others for our own incompetence is a lesson in stupidity...
The issue at hand has been solved.
This is going to get REALLY interesting ..
LL
AC
Lottalead
I think the HES has a high base load. A single effect is only produced if the base load is significantly  :)exceeded. In other words, the HES does not regulate itself according to the load, but operates within a fixed consumption window.
Mistakes? LOL
Technological refinement, many brilliant minds were added to the fold... once they found who they could trust... Astra..
It's already been done.. you're a year behind.
Good luck with your new venture ..
LL
LL
