TommeyReed
Hi SL,
Sorry, I don't know why those pictures were so big. I just removed them.
Tom
SolarLab
Tom,
Thanks, much better.
BTW a guy just sent me the attached video of a Needle Winding set up.
Looks like it would be easy to set up a 3-Axis Knee Mill to do the winding;
and, if you have a Rotary Table (4th-Axis) might work for doing a round frame
multi-pole (both pole and lap?).  I know your building a mill...
Will keep this in mind when I try to write the code (maybe an Arduino Uno - one
of the free boards/chips supplied within Martix Flowcode V10 [it's a nice
programming package actually - easy and fast code development - flow chart, etc.].
Probably easier to do in a micro than in G-Code (?).
https://www.flowcode.co.uk/  (disclaimer: I have no nothing with Flowcode - but I
did purchase the Pro Version and the STM ARM code pack)
Needle Winding video attached:
SL
Lottalead
SolarLab
LL - Not me man!
There is still several items that may need attention:
Reviewing the Philips Ortocyclic paper closely, in particular the Fig. 4 diagram, the first layer is layed
down with a crossover (90o - alpha crook) at each turn. Then at the end of the first layer the coverage
is only to "1/2d" from the total spool guide (n+1/2d) but the second layer "crooks" 1/2d as it moves
up to start the second layer. The second layer crooks in the opposite direction for each turn.
Looks like the spool form would need a " - 1/2d "  inner ring in the inside at "n+d" if the wire were
thin (how thin or small diameter is yet TBD).  The rest of the coil should track ok since it will follow the
underlying groove of the layer below it.
3D Printer resolution has to be fine enough to allow for this "inner ring" and provide a thin enough
flexible outter edge so the width of the needle can "flex outward" as the needle is passing and then
recover to it's original shape to hold the wire in place when the needle has passed.
The Coil Former Spool would ideally be a 2 piece design so it can be removed if required.
It would also be nice to find a 3D Filament that rejected Crazy Glue so that only the winds could be
bound together without heat while the two piece bobbin core former could be removed if needed
leaving only the bound wire core.
Attention to the space factor shown in Fig. 8 can be dealt with using the formula provided in the paper
but the stepper motor step size would have to be fine enough to accomodate the smallest wire
diameter used.
If there's more (or I've missed something); please let me know!
The full Philips paper is attached following the figures.
Regards,
SL
rakarskiy
Quote from: onepower on July 08, 2023, 12:43:49 PM
Rakarskiy
Yes and yes.
Perpetual- Lasting forever; never-ending, continuing or being so for an indefinitely long time.
Motion- The act or process of changing position or place.
Machine- A physical system of fixed and moving parts that performs a task.
The atom has fixed (Proton) and moving (Electron) parts.
An atom is in perpetual motion and it's parts cannot be created/destroyed or stop moving.
The atom also performs the task of being the building block of all physical things in the known universe.
By definition and for all intensive purposes the atom qualifies as a perpetual motion machine.
The problem seems to be that many choose to view things on a superficial level in a subjective manner.
They build a nano-machine made of a few atoms which performs a task and think it's the holy grail.
Where nature has been building machines from atoms into larger and more complex machines for billions of years.
It also helps to understand logic and reasoning to help spot obvious contradictions.
1)The conservation of Energy demands energy cannot be created/destroyed.
2)The conservation of Mass demands the atoms Proton/Electron cannot be created/destroyed.
If the energy and mass of the atom cannot be created/destroyed then it is by definition perpetual.
What do people think "cannot be created/destroyed" and "perpetual" mean?.
Which is where things get a little weird because anyone claiming "perpetual motion" is not real
obviously doesn't understand the conservation of energy and mass.
AC
Hi onepower!
There is no need to confuse the concepts of philosophy, physics and engineering product! Perpetual motion - defines a process consisting of many processes (rocking-end) making up a chain. For an engineer, an engine is a mechanism that performs work. The term "eternity" is also inappropriate for an engineer, who creates a device with a period of operation, a resource of mechanisms and components.
Taking a permanent magnet, this is a product that is produced by the appropriate technology.  It can be defined as a "single-start magnetic field generator", any magnet has parameters, operating conditions, etc. The magnet built into the door magnetic latch, by closing the flux generated by it through the closed magnetic circuit, holds the door closed condition, for the product of another engineering product - cabinet. no body movement, but the work of holding the door closed is performed. It can be estimated by making a latch made of an electromagnet instead of a magnetic latch on a permanent magnet.
That's how simple it is, you can evaluate "conditionally infinite" source of magnetic field - permanent magnet.
