rakarskiy
Quote from: bistander on August 07, 2023, 09:22:56 AM
So you make a global conclusion from one instance of hearsay of difficulty in sourcing material for some undefined application. OK?
Concerning motor vs generator.
In the development of medium power 100-200kW motors, load testing dynamometer equipment was prohibitively expensive for our operation. The solution was to use two prototypes coupled shaft to shaft via torque sensor. Operate one as motor and other as generator. Both motor and generator ran with equal efficiency, within a few %. Power was looped so only a fraction was required from the grid. And large power was not needed to be disposed from load.
The recent development of electric vehicle motor systems is a prime example of a single machine used as both motor and generator. During regenerative braking the systems work as efficiently as during acceleration. No rewinding required.
Yes, I agree some generators make for crappy motors. Lundel alternator is one. I'm sure there are examples of motors running poorly as generators. Application specific features have much to do with it. But fundamentally, motors and generators are the same.
bi
No rumors, the optimal steel was selected for the model (combined excitation alternator) and it took time to find it. That being said, it is simply not available in the remnants. The guy found it unclaimed because the project was canceled due to the war.
kolbacict
Quote from: Sergh on August 07, 2023, 09:18:10 AM
Motor  without steel:
We recently looked in one of them.
And also the micromotors of cell phone vibrators also do not have an iron yoke.
Quote from: bistander on August 07, 2023, 09:36:29 AM
For the purposes and intent of this forum, I'd say not.
Unless of course you have your household or car running on such a device.
bi
FE related ' extraordinary'results,do You,bistander,find as Nobel Prize Award in Physics or Nobel Prize Award in Chemistry ?
By Your personal definition or conventional academic nomenclatura ?
Related theme : inbalance,A-Symmetrie
Probably actually,grid-connected,You get,partial,FE ! Photovoltaic,Aerovoltaic,T(h)ermovoltaic !
wmbr
OCWL
p.s.: shocking  :o ,no special steel/alloy,
          #8 ,2006
         https://overunity.com/1645/common-batteries-are-free-energy-sources/
        Good old time/s ! ;)
        'no title available' ,but cw/ccw internal process :
        https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=BE438189&AP=&PR=&PD=&PA=&IN=&CPC=&IC=&Submit=Search
       An virtual gear process,problem : cube= v³ potenz increase/decrease ( -³) re-/action time/gravity(inertia)
       Does this explain the internal EE process,mechanical/kinetical :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=19840807&CC=US&NR=4464095A&KC=A#
Quote from: rakarskiy on August 07, 2023, 09:03:24 AM
Where can I find a copy of this patent, according to the description the design coincides with the MEG of Tom Bearden and Co. or EasyMEG, only in such a configuration as a generator works only EasyMEG and that I had to specify something.
In the espacenet-page ,left side : original document ( in french )
Or please the french INPI a paper-copy ! Or print the ' original document'-pdf out !
https://www.google.com/search?q=pdf+translation+app&ie=utf-8&oe=utf-8&client=firefox-b-m
wmbr
OCWL
bistander
Quote from: lancaIV on August 07, 2023, 12:35:33 PM
wmbr
OCWL
          #8 ,2006
lancaIV Sir,
I must disregard your post as it is incomprehensible. Appears to contain two questions directed to me. If you rephrase, I'll attempt to reply. Respectfully.
bi
