rakarskiy
You're being vain here. There are two aspects to this question:
One! Is the technology working? My answer is absolutely in principle - working (in the question whether it is possible to run a generator without physical rotation of the magnetic rotor in a static stator) This technology, in addition to the claimed possibilities of working without physical rotation, has many technical and managerial problems. First, this technology, when scaled up, will have more problems of compliance with the conditions for electrical mechanisms (watts/kg). Today it is very expensive, and it will be even more expensive to install 100 kW, even with changing load characteristics. What I see is that the power key industry is already needed for such installations, and it is not becoming cheap in terms of hardware components.  It is for this reason that much more fundamental research is needed. It is already a question of integration and commercial attractiveness. In order to invest in a pioneering project, all risks have to be taken into account, from the intellectual and production capability of the authors to the system of counteraction from other participants in the power generation and generators.
The second issue is the correct operation of the final converter! In order for the condition СОР>1 to be met, the consumer must be provided with a constant load greater than the mains consumption of the unit.  If you think that the device itself will guess when to switch, you are mistaken (now substitute a system of constant starts of the system and its stops with a mechanism of switching directly to the network during the day of operation, if you can not do it you will be ...), and with the input load characteristic for example input consumption of 10 kW, will not change if you connect at different time intervals 5 kW, 10 kW and 20 kW to 12 kW in fact you will be at a loss just paying for the operation of the system without getting the performance of useful work.  The issue of claims arises. If you have a volume of energy consumption of useful loads is less than the volume required at the input of the system Holcomb, and you purchased this device who cheated you, Only themselves and their own energy illiteracy.
PS
Investing in pioneer projects should only be done with a long term perspective, thus the second side of the project appears - investment/commercial. I am no longer interested in it. In this area, manipulation is possible due to ignorance on both sides. Once again, I assert that I am not interested in them, but only in technical solutions (successful and erroneous).  Only an ignoramus can claim that Holcomb's solutions are always successful, any creativity is a path of victories and mistakes. Personally, I wish Holcomb and his team to overcome all difficulties and not to lose the technology.
I have completed an interesting piece of research, the invention of the electromagnetic generator! This material is not intended for the reader with popcorn! Just the principle on which Holcomb's generator works can be understood.
Faraday was the very first researcher of electricity who followed open code in research Quote from the letter: "I believe the author can have no objection to the publication of his letter; for my part, I would prefer to avoid exclusive possession of anonymous philosophical information, lest future errors in dates occur."
TommeyReed
rakarskiy,
You are sounding like SL, theories without proof.
Holcomb claim a COP of >2, you're say a COP > 1 is possible.
I'm tired of these claims without a prototype to prove it, I'm not the only one here that see the BS meter going through the roof.
Where is you're prototype?
Even better, I'll help build it. Why are all of the clowns one these forums who thinks they are smarter then a fifth grader, can't even build a simple prototype?
Holcomb use Chinese motors and if you know anything about those motors it's not that hard to rewire to fit your needs.
You can even test these theories with even a stepper motor, that is how the Holcomb motor/generator is based on.
Just look at all the solid state switching that he used, it's clearly pulsing each field. I built motor and rewired motors, it's not that hard to copy a Holcomb generator.
All the BS with different metals is not the case, when he used Chinese cores.
Unless Holcomb stamp out his own stators, that is highly questionable; it should be no problem making a copy.
In fact you can modified those Chinese motors and clip and tap into each field without rewiring them.
Just show, you don't have to be a PHD to understand how something works!
https://www.youtube.com/watch?v=XMrzFDoHXjE
Tom
stivep
Quote from: ramset on August 20, 2023, 10:57:12 AM
Investors // line their own pockets ////to harvest for personal benefit
Plenty try to use open source FE
// open source FE//freely share ( withholding nothing)
// there are plenty who are sincere...
Open source FE is // a mindset , a survival
We are destined /
Our future depends on it !
// all here // we support ! regardless the nonsense written here .
Others should truly go elsewhere ..
Respectfully
Chet K
___________________________________
I see here : postulates of Marks and Engels about
  the " dedication, equality and good  future,"
   where wealth, food, technology, skills and dedication,
      is given for free by these who have it to these who do not..
        - Lenin, Stalin, Putin where  the practical result of it.
Idea is beautiful,
  goal is  fair,
    motivation  is well supported
       physicist  helping the illiterate
         literate in art  gives a physicist some painting as thank you for FE.
            and  of course  not everyone has a house, computer, and electric car  too.
             but they should be given that too
               shouldn't they?
Wesley's wife.
The psychologist.
TommeyReed
psychologist,
Someone who explain others people mental state, perception, cognitive, emotions and behavior, yet never looks in the mirror!
What do a psychologist offer in these forums when they can't even change a light bulb?
Tom
adrouk
Quote from: stivep on August 21, 2023, 07:46:55 AM
  the "good, dedication, equality and good  future,"
Idea is beautiful,
  goal is  fair,
               shouldn't they?
Wesley's wife.
The psychologist.
I'm not sure that you read and understood the header on the first page of this forum. Because if you did I am questioning your post in this forum , or why do you need to stick around ?
Also when you try to draw a parallel with Lenin-Putin you simply forget to say that their social system have the most benefit from energy markets are their interests are in a real danger by letting FE in the open for everyone.
And the last, I am losing my patience seeing how you twist the truth all the time when you run out of any reasonable argument and you keep inserting this kind of malefic things on most of the threads where I don't want to disturb and I need to apologise for the rant.
If you really believe that free energy should be shelved, why are you here ? Who you help really ?
